Old 10-26-2011, 07:04 AM
THE NEW GUY THE NEW GUY is offline
rear window defrost does not work
Any ideas on how to diagnostic and fix the rear window defrost system? the light on the switch comes on but the window remains foged.
Does anyone have the link to the complete electrical diagram?
Is there any guide to find the fisical location of any component?
Thanks a lot to everyone.
Old 10-26-2011, 08:32 AM
Re: rear window defrost does not work
The complete electrical wiring section for the SVX, including the rear window window defroster section (which starts on page 68) can be found here:
http://www.phantomotaku.com/SVX/MSA5...ng_diagram.pdf
These are exact reproductions of the FSM. Download what ever you need from here. Quite handy:
http://phantomotaku.com/SVX/
Old 10-26-2011, 09:51 AM
The defroster in my blue car doesn't work, because the part that connects to the heating element on the glass broke off at some point. It's at the very top center of the back windshield. Have a look at it. I am planning on sticking it back on there with some of this stuff, after I get rid of the tint (too dark): http://www.amazon.com/Permatex-21351.../dp/B000HBGKWE
Old 10-26-2011, 09:58 AM
if you have a voltmeter or test light you can check for power and continuity right at the strips running across the window. one side of the grid is power and the other ground, very common for the strips running down the sides to get little dings in them and stop working completely. hope you don't have tinted windows as this makes it a lot harder.
Old 10-26-2011, 01:59 PM
Thanks guys. this is fantastic. Nobody else have such a wonderfull car and with such a preciated help on line. This is reserved to SVX lovers.
Old 10-26-2011, 02:10 PM
Download the Body Electrical Manual .pdf from the above site. The procedure for testing the rear defroster wires is on page 21 and repair on page 22.
http://www.phantomotaku.com/SVX/MSA5...electrical.pdf
Old 10-26-2011, 02:33 PM
I fixed one of my grids with a kit from Kmart. It had a little stencil thing you put over the break and then there was this nail polish looking stuff you painted on it.
Old 10-26-2011, 03:12 PM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
i could use some of that stuff cus someone tried to get the tint off the back window with just a scrapper and some of my defrost doesnt work now
do you know what its called??
Jared
1992 dark teal SVX LS
Old 10-26-2011, 03:35 PM
dennyo dennyo is offline
My 96 had the same problem when i bought it. Turns out the ground wire was not attached.It's located right by the antenna where it comes through the quarter panel.In the trunk.Works fine now. The body shop that painted the car didn't hook it back up when they were done. Thank god for FSM.
Old 10-26-2011, 03:51 PM
Permatex® Quick Grid™ Rear Window Defogger Repair Kit
Old 10-26-2011, 05:01 PM
That's it the stuff I used . I remember the little bottle . I did not get the tab mounting kit with mine . I may have bought mine at Big Job Lots
