Old 10-16-2011, 08:44 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Prototype Spoiler
Hi all, i've had this idea in the back of my head since i got my svx, and i was wondering if anyone else has done it/thought of it. i found pictures of someone who had done it, but i can't remember where they were on the vast land of intern3tz. anyway, what i wanted to do is use my spoiler and add a little bondo or fiberglass to it to make it flush with the trunk, like the prototype svx was.
the only thing is, i'm not very fond of how far back the wing sticks out:
i can't tell from this picture, but it looks like this guy did what i want. it just looks cleaner to me.
stock wing, just a little bit added to the sides to make it flush. comments/ideas? it's just a thought of mine, and i still have to fix a few things before i invest money on cosmetic issues. what would i need to do to achieve this? is it a big deal? thanks!
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 10-16-2011, 08:50 PM
dbarnblatt's Avatar
Re: Prototype Spoiler
The red car IS the prototype. It started it's life silver and was repainted red by Subaru a few years later.
What you want to do sounds really cool... I think finding a good fabricator/custom body place to do it is the trick.
The Trunk is fiberglass so it would be a pretty basic job as far as materials... just talent is needed to make that shape just right!
Have fun with it!
Old 10-16-2011, 09:16 PM
http://www.subaru-svx.net/forum/show...t=50767&page=5
You're welcome
Old 10-16-2011, 09:49 PM
fun173's Avatar
fun173 fun173 is offline
#1 BRODAWG!
I thought that picture of the red car was a 3d rendering?
Old 10-16-2011, 09:52 PM
B 4 You's Avatar
#lolsvx
YES. THANK YOU. that is exactly what i want to do. i think that looks so much cleaner. such simple things can make such big differences. are there any pictures of the finished product? also, the JDM wing is too high for this, i don't like it. i would keep my wing and blend it into the trunk. maybe i'll get some black clay or playdough and see how it looks
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-17-2011, 02:05 AM
I have looked into this some (including PMs back and forth with Elliott) and here are my conclusions:
1 you need a pearl white or maybe silver car and a US, not JDM style wing.
2 and a really good body shop to do the work.
3 you need to get the spoiler, shave off some of the base of it so that it has a better angle of attack (if you don't it will angle downward at the back, creating lift instead of downforce and looking silly), and slide it back 1.5 to 2 inches (elliott went too far back).
4 you need to delete the antenna and add some material to the sail panels so that the tips of the spoiler start way up there.
5 use lots of whatever kind of filler to smooth it out.
6 the spoiler is hollow, you have to make holes somewhere for air to escape otherwise when it heats up the spoiler might pop.
7 you can actually put an antenna inside the spoiler or somewhere else inside the trunklid. They are fiberglass, so you should still get reception just fine.
8 bonus points for relocating the middle brake light from the trunklid to the spoiler. might as well while you're at it, right?
9 If done right, the sail panels and trunk should be able to be removed and replaced and the trunk should be able to open and close freely just like stock. Plug and play
Old 10-17-2011, 06:33 AM
If I went that far I would shave the door handles and power operate the doors. looks like it in the primer version
Old 10-17-2011, 11:18 AM
B 4 You's Avatar
#lolsvx
i like it. i would do all of that, minus the tail light in the wing, because i would then have to fill the trunk more. ballpark, how much do you think this would cost? (not even slightly serious, i'm just toying with the idea for future reference. now i know it is indeed possible).
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-17-2011, 11:40 AM
I'm not sure, but I know it would cost a very large chunk of money.
Old 10-17-2011, 02:08 PM
Huskymaniac's Avatar
Uses the ignore feature
Forget all that. I want the 5 spoke star rims!!!!!!
Tony
