Old 11-14-2011, 12:48 PM
Re: 500 awhp?!
Realize that even 350 whp is over 475-500 crank hp with an MT
That reminds me, my build advice was for ~350-375 at the crank, not the wheels.
Old 11-14-2011, 12:53 PM
Re: 500 awhp?!
Not any more than the VW I saw with the front mounted 327 Chevy V8<LOL> When he came to the light you expected to see a driver you saw an air cleaner . He sat in the back seat. If you got the time skill and Money you can do anything. I bet he scared quite a few Street Racers . The SVX is just too heavy to win many off the line races . You would be better of trying to take off 600 or 700 lb than to raise the HP 50 or 60 hp. a 3,000lb 250hp car would be competitive at the DRAGS
Old 11-14-2011, 06:26 PM
immortal_suby's Avatar
Thread Killah
Re: 500 awhp?!
You could always do a 150hp wet shot of nitrous.....Much cheaper to implement - even if you blow a motor apart you're still going to end up way ahead of trying to do a turbo or supercharger build. LAN used to sell a setup made for it with an ECU chip to retard timing, jets that plug in to each throttle, etc.
Locker Link
2015 BRZ Limited 6MT
Old 11-14-2011, 08:12 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
Re: 500 awhp?!
Oh that's right, you're an SVX owner. I should rephrase, to do it PROPERLY, have fun spending $30k on a full and proper build up of a car
so the way that goes does anybody actually do it the proper way?! it seems kinda dumb not to buy an STI with 2 turbos! that'd cost $40k-50 total
Originally Posted by 92snowmachine View Post
if you really want to spend the money and really want that much power there is one option i considered. dropping a northstar v8 in the back seat, since it's fwd use axle for one wheel to power rear diff and the other to the front. they come with 300hp stock and are capable of a lot more. only reason i considered it was when i had a totalled caddy with a good engine and had seen my buddys rock crawler. apparently it's a new craze with them because the northstar is really light pretty small and it eliminates the need for a transfer case or center differential. i actually measured the back seat and trunk area. would take lots of fab work but would fit rather easily. if you are going to spend the money might as well make a mid engine awd beast.
does this actually work? what tranny and diffs to use? how much frame work needed?
that makes it around 275 to the wheels! subis are hard! all that trouble for a little over 100hp gain!
VW golf? how can you fit a v8 in place of a VR6/i4?! i know that putting a V8 in the front will change the handling dramatically(if it fits) this is probably a cheaper option but has other problems...thanks for the advice
that is gonna be dangerous! but i may do it if i don't find a cheap STI
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 11-14-2011, 09:10 PM
Re: 500 awhp?!
Sorry it was a 1980 VW BUG with a V8 up front
Old 11-14-2011, 09:28 PM
Green1995SVX's Avatar
Re: 500 awhp?!
I doubt you'll find an STi for under $1000.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 11-14-2011, 09:47 PM
The NEWBIE
Re: 500 awhp?!
true but i rather spend around $10k on doing a proper tuning
DIY FTW!
Old 11-15-2011, 08:25 PM
Re: 500 awhp?!
yup, uses the same trans as the caddy, not as much frame work as you would think. you make tubular engine/trans cradle and weld it or bolt it to the car. you can use any diff you want but i would think this setup would destroy most diffs that come on subarus.
Old 11-15-2011, 09:02 PM
The NEWBIE
Re: 500 awhp?!
so it's probably going to be an RWD, mid engined V8 SUBARU! those words don't go together! if i found the time and the money i'll probably buy a dead SVX just for that purpose...my engine and tranny are good for now!
but that's gonna be one scary beast....
appreciate the help tho
DIY FTW!
Old 11-16-2011, 03:14 AM
Re: 500 awhp?!
I want to buy a ticket for ride in that car
Old 11-16-2011, 08:45 AM
Re: 500 awhp?!
i was planning on making it awd. was going to buy a junk svx just for the project but lost motivation. if you mount the fwd northstar transversely then you can use the right and left axles to be the front and rear axles, and actually would make it way easier to fit. the caddy the engine came from weighed about the same as the svx and did 0-60 @ 6.8 stock but was basically limited by being fwd. people look at you funny when you light up the front wheels and chirp 'em into 2nd and third.
Old 11-16-2011, 11:21 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: 500 awhp?!
Wait! We can get you to 485hp! <clicky>
Old 11-16-2011, 04:00 PM
The NEWBIE
Re: 500 awhp?!
getting the power is not hard....putting it down and keeping the tranny and the diff alive is:P
DIY FTW!
