Go Back   The Subaru SVX World Network > SVX Main Forums > Technical Q & A > Chris's SVX Shop
Old 06-15-2007, 01:09 PM
HumpSVX's Avatar
HumpSVX HumpSVX is offline
Send a message via AIM to HumpSVX
Rear Wiper trouble
I bought my SVX about 3 days ago, and the rear window wiper was not working. I checked today and found that the fuse was blown. I replaced the fuse and now it STILL doesn't work. When I turn on the wiper, I can hear the motor running or something making a noise like its running but the blade is not moving. I'm not sure on how to remove the plastic things that hold the carpet lining of the trunk in place so that I can get to the motor. I'm afraid of breaking them. Do I just unscrew them, or are they more like nails and I can just pull them straight out?
Also, if anyone has experienced the same or similar problem, can they post what they did to fix it? So that once I get in there I can have a better idea of what to do with it
Thanks for the help guys!
-Hump
'99 RBP Subaru Impreza 2.5RS
'92 Pearl White Subaru SVX - 136k - My first SVX -traded
'92 Yellow Subaru SVX LS "Bert" - 123k -The first SVX Convertible
'92 Orange Subaru SVX LS-L "Ernie" - 139k -The first SVVVVVVX (stretched SVX limousine)
Okay, so the bottom two cars don't actually exist but what if?????
Old 06-15-2007, 01:19 PM
Bah, just remove the wiper and asociated parts.
Old 06-15-2007, 02:32 PM
That would leave a nice hole for rain to come through.
Remove the wiper arm and see if the gear moves. The arm or the gear could be stripped.
Old 06-15-2007, 04:00 PM
The disks just pop off. I use something flat to pry them off. Like David says, check the wiper part first.
Old 06-15-2007, 07:48 PM
XT6Wagon XT6Wagon is offline
did the SVX come without a rear wiper anywhere?
Old 06-15-2007, 09:12 PM
sharky512345 sharky512345 is offline
Send a message via AIM to sharky512345
Did the tip of the wiper get stuck in the trunk? That happened to mine and I had to reposition it.
Current: 2005 Black Legacy 2.5i 63k
Previous: 1996 Brilliant Red SVX LSi 117k
Old 06-15-2007, 10:26 PM
HumpSVX's Avatar
The car did have the wiper when i got it. I just got my SVX less than a week ago, and it didn't work when I got it. It may have gotten stuck in the trunk by a previous owner, which caused some problem, but not because of my doing.
-Hump
Old 06-16-2007, 09:57 AM
Have you checked it out and have you found anything?
Old 06-16-2007, 10:15 PM
HumpSVX's Avatar
Not yet, I work weekends. I'll probably mess with it Monday. It's lower on the list of priorities of things that need fixed. (I wish it was all that needed fixed ). It's something I'll mess around with when I don't have tons of time to do work on the car.
-Hump
[IMG] code is Off
