Old 07-05-2009, 12:14 PM
Green1995SVX's Avatar
About to replace transmission output shaft seal. Any tips?
The title says it all. I'm about to head over to the shop to replace my output shaft seal and hopefully actually have a transmission that holds its fluid again.
Anything that I should know?
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 07-05-2009, 01:00 PM
Re: About to replace transmission output shaft seal. Any tips?
Its a PITA to get out. Just make sure when you put the new one in to absolutely sure it is completely flush with the bellhousing.
Old 07-05-2009, 02:45 PM
Mike
Pack it fully with petrolium jelly.
And coat the lips with the same.
Old 07-05-2009, 03:13 PM
michael's Avatar
michael michael is offline
What Potholes ???
Buy it a drink first!
Wanted: Steering Wheel
Old 07-05-2009, 04:10 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-05-2009, 07:08 PM
Don't worry. I'm always the gentleman.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 07-05-2009, 08:20 PM
immortal_suby's Avatar
Thread Killah
Locker Link
2015 BRZ Limited 6MT
Old 07-05-2009, 11:31 PM
NiftySVX NiftySVX is offline
Send a message via AIM to NiftySVX
Get a seal puller, pry it out, put a new one in, coat it with something so it doesn't have any dry spots, and you're done!
Shouldn't take more than about 5 minutes once you have the shaft out. Also, I would look at the yoke of the driveshaft and see if it has any imperfections that might have caused the seal failure. If you'd like, you can remove the dust shield on the extension housing for more room.
2007 GS 450h-Active Stabilizer/Radar cruise
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Toyota Master Diagnostic Technician (former life)
Old 07-06-2009, 04:39 AM
I just realized you said output shaft seal and not input... They are easy but like someone already mentioned they really only fail for a good reason and finding it is key
Old 07-06-2009, 09:00 AM
I wondered what you were talking about when you said "bellhousing."
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 07-07-2009, 07:53 PM
I finally got around to doing this today. It was a very easy job. Getting the old seal out was a little difficult, but overall it wasn't too bad.
My car doesnt pee out atf anymore!
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 07-08-2009, 07:43 AM
SVXRide's Avatar
+1 for non-atf peeing!
-Bill
Old 09-04-2009, 03:22 PM
storm66's Avatar
storm66 storm66 is offline
Imagine...
Anyone got a part number for the driveshaft (output) seal. Is the seal the same on a 5 spd Legacy transmission (5spd swap) as the AT?
94 Laguna Blue LSI 126k (stock)
92 Silver LSL 106K (highly modified)
Old 09-04-2009, 04:09 PM
trophy956 trophy956 is offline
hi drive shaft seals have different part numbers but are interchangable
