Old 06-18-2013, 05:25 AM
Losing Brake fluid
I've been losing brake fluid on one of my SVX's, but can find no leaks anyone else have this issue, and find the culprit?
I've replaced the master cylinder, and searched for signs of leaks, but have found none...
Old 06-18-2013, 06:19 AM
Re: Losing Brake fluid
How fast do you lose it? Can you park the car, pump the brakes and empty the reservoir?
If it's not around one of the wheels, my next guess would be the lines around the fuel tank
Old 06-18-2013, 08:12 AM
Sometimes I can drive for days without noticing it, and sometimes it goes pretty quick....never find any wet areas, and this is a southern car, with no rust, I' really don't expect it to be the lines over the tank, but even if it were, it should be leaving a puddle...
Old 06-18-2013, 06:28 PM
If you can't see any leaks Huck, it may be going through the booster vacuum hose to the manifold.
Old 06-18-2013, 08:52 PM
Thats what I was thinking, but he replaced his master cylinder.
Old 06-18-2013, 09:19 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Look under your car right where the lines go under the rear passenger seat to the underneath of the vehicle. There's a little "intersection" that the lines go through before going over the fuel tank. Mine was leaking but no fluid would show up anywhere, and that's where it was coming from.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 06-19-2013, 05:18 AM
I'll look there again, but had it up on the rack Monday night, and didn't notice leaks anywhere....
And Harvey, that should be ruled out, since I've replaced the Master cylinder....but I did pull off the vacuum line to double check, and it is dry inside..
Old 06-19-2013, 05:44 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I would try putting cardboard under each tire while it is parked and pump the brakes. I had a small leak in the rear and it would never leave a wet spot on the ground except until I used a cardboard. Try it.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 07-03-2013, 05:09 AM
It ended up being the left front rubber line to the caliper...wouldn't leak all the time, but would under the right conditions....Got a new one on the way...
