Go Back   The Subaru SVX World Network > SVX Main Forums > Product and Service Reviews > Exterior Car Care Products
Old 10-14-2010, 10:42 AM
jdsnc82's Avatar
jdsnc82 jdsnc82 is offline
Headlight restore
I have been trying alot of different headlight restore kits and i found one that works great! Its the turtle wax kit from auto zone. It damn near put my headlights back to new in one use.
Party like a rock star, rock it like a porn star, and drive it like you stole it. Life's short, live it
Old 10-14-2010, 10:50 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: Headlight restore
I think a lot of products work great, but it would be nice to sort out which one lasts.
Old 10-14-2010, 10:53 AM
StatGSR StatGSR is offline
Send a message via AIM to StatGSR
what grit of sandpapers does it use?
iv always just done it with great success with various wet sanding paper (400 - 2000) and some 3m rubbing compound.
one of my before and afters on my integra corner lights. i didn't even go up to 2000 grit with these, and the buffing was done by hand.
Rob, as far as what lasts it depends what you use to protect the lens over time. any wax or polish will disappear over time leaving the plastic exposed to the elements once again.
I just don't think that most kits include a lower enough grit to actually work out the larger nicks and dings in the lens. I have started with 400 and or lower on lens restoration.
94 Acura Integra GSR
97 Legacy Brighton - EG33 Swap still in progress
03 Silverado 2500 - Duramax
Old 10-14-2010, 12:20 PM
Huskymaniac's Avatar
Uses the ignore feature
Just bought this. I like the combination of items in the product. I will report back on my experiences.
Tony
Old 10-14-2010, 01:32 PM
Manarius's Avatar
Manarius Manarius is offline
I used the Turtle Wax Kit. In 6 months they were back to being yellow. I think the key here is that clear coat is necessary to stave off the yellowing. Clear Coat turns 6 months until yellowing into 2+ years.
-Jason
-Obi Wan Kenobi
Old 10-14-2010, 02:05 PM
That is true of any restoring product. The question is, how much does it cost and how easy is it to use. This one seems like a good product.
I wonder if a coating of high quality wax will protect the headlights. I will finish my restore with a coating of Collinite.
Tony
Old 10-14-2010, 02:37 PM
^ yes consistent waxing will keep the lens surface protected.
Old 10-16-2010, 08:17 PM
Gave this a try today. I will say that I could still see surface scratches after going through the 4 stages of grit and the polishing compound. On the second headlight I skipped the coarsest grit and the results were better. Perhaps there is too much of a jump from the coarsest and the second coarsest grit. I did like that the kit came with a clear coat finish of sorts. You just wipe it on and let it cure. I will top that with Collinite tomorrow. For the price, this seems to do a decent enough job. But my lights weren't that bad and skipping the coarse grits would have been OK for me.
Tony
Old 10-24-2010, 10:26 PM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
How much is this kit? Walmart does this as a service for around 30-40 bucks and it lasted me a good year before fading. I watched them do it and it was 3 levels of wet sanding and a clear coat wiped on.
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 10-25-2010, 12:11 AM
The quality plastic of the SVX headlights is prone to fading whatever you do.
Now I have the "German" glass headlights, but if I were to stick with the plastic ones I would do this:
1- Make one pass with a 800 sand paper;
2- Spray 5~6 layers of clearcoat;
3- Let them bake in the sun for few days;
4- Use a 1500 sand paper to get rid of impurities;
5- Leave in the sun for another day;
6- Polish.
Old 11-20-2010, 03:13 PM
michael's Avatar
michael michael is offline
What Potholes ???
I just picked up the 3m headlight restoration kit and I have to say I'm impressed. It took a while but I think this is awesome If you have poly lenses this is a must have, you almost can't screw up.
Wanted: Steering Wheel
Old 09-04-2012, 12:21 PM
Finally broke down and purchased a 3M Kit for $22. It is the one that goes on the drill. I had been polishing them with various plastic polishes and kits, but I was never able to fully get rid of the yellowishness, so I hope that this will take finally take care of them.
I was wondering a few things for those of you who have used it. Should I remove the headlights from the car first, and should I spray them with clear coat when done? Does anybody know if I be able to use the same kit on 2 sets of headlights?
Old 09-04-2012, 12:59 PM
You will have a much easier time of working with them if you take the headlights off the car. A clear coat would be a great idea, but I don't know what kind is the right kind to use. 1 kit might be enough for 2 cars, but it will be kinda close. Probably will depend on how bad they are.
Old 09-04-2012, 05:35 PM
bishop bishop is offline
i used the turtle wax kit and it improved a lot from what it was but not as much as i would have liked.
Old 09-04-2012, 06:41 PM
Does anyone have a clearcoat brand recommendation?
