Old 02-05-2010, 12:41 AM
The1One1AndOnly The1One1AndOnly is offline
More Leaking Issues
The cams are leaking, I don't know if its the seals or.....
What items should i order for the mechanic, in order for the cam leaks to be gone for good.
Cam seals?..............
And if the rack and pinion is leaking, any quick or easier ways of stopping it without having to replace it?
Old 02-05-2010, 01:39 AM
Re: More Leaking Issues
Man I see your posts are because of issues with your car... what's the story?
Can you please search this forum for Seal Kit?
Old 02-05-2010, 07:50 AM
^^^What he says.
Buy a seal kit, do the valve covers, timing belt, front main seal, and cam seals. Water pump is a good idea while you're in there.
As for the steering...In all honesty a reman rack is going to be the most cost/time effective way to fix it.
Old 02-05-2010, 08:43 AM
Wikedjuggalo's Avatar
Rebuilding
Make sure the rack and pinnion is really leaking. I had someone tell me mine was too but turned out to be a PS hose or something else. I can't recall exactly but worth checking into before forking out that money..
