Old 12-14-2009, 08:45 PM
Re: Got the new temp sensor..still no start
Originally Posted by Trevor View Post
Was the car starting and running OK prior to installing a new temperature sensor? If not, what is the prior history? It is time to back track and apply logic.
Also, many times new temp sensors have been known to be bad right out of the box.
Where did you get the temp sensor from?
Old 12-15-2009, 02:57 PM
JWillysvx's Avatar
JWillysvx JWillysvx is offline
JWillyG
The temp sensor code is gone, so I believe that problem is fixes. Befor the " no start" condition the check engine light would come on, the power would dramatically decrease; then the light would shut off and the power would return.
I bought the temp sensor from the dealer.
"Madness, as you know, is a lot like gravity, all it takes is a little push. “
Old 12-15-2009, 04:40 PM
It is presumed that there was no starting problem before the sensor was replaced and only a temporary loss of power.
As no code is now registering, it is unlikely that the sensor is faulty.
Therefore it appears that something else was upset during work when the sensor was replaced. What could have been disturbed? Think on even the unlikely.
Old 12-15-2009, 08:01 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
The use of starting fluid sprayed into the throttle body thru the PCV or other intake ports would be a vital provider of information.
If it starts with starting fluid, you have confirmed properly timed spark, but no fuel, or no properly timed injection
If it does not, and you say you have confirmed that you DO have spark, then timing of fuel or spark is where you should look.
Since you checked the timing belt and cam alignment already, then it would seem to be a crank, cam, or MAF sensor problem if you cant kick it over with starting fluid.
Old 12-15-2009, 10:35 PM
JWillysvx's Avatar
JWillyG
Would the MAF cause a no start? I will try starting fluid in the morning......if it is the MAF causing my troubles, should I purchase the Z32 (300z) MAF or stay stock?
What about the 90mm MAF from a 1995 Infinity Q45?
Old 12-16-2009, 08:07 AM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
A bad MAF can cause the not starting situation. The starting fluid test is a good idea, if it starts, then more likely you have a MAF problem.
In this case, is better to keep stock, unless you want to install an Ecutune or something.
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
Old 12-16-2009, 04:09 PM
kwren's Avatar
kwren kwren is offline
Maybe... But could a bad MAF prevent starting on a car that started "before" the temperature sensor was replaced.
Logic must be somewhere in the equation...
Keith
Old 12-16-2009, 05:41 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Keith
A new temp sensor was installed, dealer temp sensor.
Maybe he should resistance test it, or just leave it unplugged while cranking it over. A bad temp sensor right out of the box isnt unheard of.
Hopefully the starting fluid test will shed some light, with confirmed spark and confirmed fuel apparently, the only thing left is the timing of such, which will narrow the suspect list down a bit.
Im wondering if the regular unleaded gas thats in the tank is causing the knock sensors to retard the timing enough to cause a no-start..... that could be a factor as well.
Old 12-16-2009, 06:03 PM
A bump towards applied logic.
Old 12-16-2009, 06:41 PM
Is your TPS plug fully seated?
Old 12-16-2009, 07:29 PM
subeman90's Avatar
Soobologist
Hocrest who?
15 OBW premium w/eyesight
Old 12-16-2009, 08:14 PM
Originally Posted by subeman90 View Post
Hocrest who?
TEEHEEHEEHEE, snort!
Actually the wiring and TPS plug are in the "neighborhood" of the water temp sensor, so it is possible to bump it loose or, break a wire there.
Old 12-16-2009, 09:08 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Correct me if im wrong, but doesnt the engine have to run for a bit before new codes could be set in the ECU? Or does the ignition just have to be on? Logic suggests that he check where he was working, as mentioned, but if he did get a bad temp sensor, could it still kick a code even on a no-start?
Old 12-16-2009, 09:11 PM
JWillysvx's Avatar
JWillyG
Shot starting fluid directly into the plenum with the MAF unplugged.....nothing, not even a sputter Checked all the plugs, they are good. The no start problem has been a monkey on my back for months now, there has to be something simple I am over looking here
Originally--I parked it , shut it of then went to start...no start, tried to start on one or 2 cylinders but not enough to run.
Have spark, fuel...tomorrow I am going to pull a spark plug to check compression and spark timing.
TPS...throttle positioning sensor?
Old 12-16-2009, 09:14 PM
kwren's Avatar
I would put the old temperature sensor back on and see if it still does the same as it did before replacing it... start but not run well...
might help you decide about the condition of the replacement sensor.
Keith
