Getting gas out of gas tank.?
I need to get my gas tank down to 1/4 tank for an indoor show. Any ideas on how to do it without driving 200 miles?
1994 model with no mods. |
Re: Getting gas out of gas tank.?
unhook the line at the fuel filter, direct it into a tank (or another vehicle), jump the fuel pump relay with a paper clip. if you remove the relay and start the car it will help to depressurize the lines so you don't get sprayed with gas.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
^This sounds better/smarter than the siphoning suggestion.
I did it once by putting the line from the fuel filter into a 2 litre bottle then turn the ignition key to the ON position. The pump runs for a few seconds then cuts off. You get about 0.2 litres of fuel in the bottle. So just cycle the ignition key 10 times then empty the bottle and repeat.
It could take a while, depending on how much fuel you want to drain.
