#76
I need pics of the stub in the trans with no axle on it... Its the only way to tell for sure
Tom |
#77
So I have to pull a axle back out????
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#78
Hey Bobby,
Could ya update me on how its going with the jdm oil lines and cooler... perhaps I am gonna go ahead and do the same if it is cost effective. Thanks, -Sov13t. P.S.: Quit picking on CCCP
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd |
#79
So what is the verdict? Should I use the axles and see if I blow gear oil out? If that happens then try to figure out a solution? What are people with the 6mts currently using for front axles?
#80
If the car is together then you should just see if it blows oil out. With my 5 speed it did but not the 6 speed. Used the stubs from the auto with standard SVX front axles. I think the seal issue depends on which model gearbox you got.
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#81
<<What are people with the 6mts currently using for front axles?>>
i have the STI tranny with the axle stubs already sticking out of the tranny. my stock svx axles fit right in. |
#82
dumb question but what are we calling axle stubs?
#83
<<dumb question but what are we calling axle stubs? >>
circled in yellow |
#84
ahhh okay...... I am going to see how it goes, if I leak, then I leak and I will have to figure out a solution then. My pedal box is almost in. Once that is in all I need to do is mount the starter, do the little bit of wiring, reassemble the intake and TB's, mount the linkage, bleed the clutch and brakes, and voila...... Done
#85
The Ultimate in Leak Protection for Men
bLAh
#86
Just kidding. actually, now that I think about it, YT wOULD be done by now!
#87
Bobby in this picture if you look at the diameter of the shafts where the seal is to the front differential you will see the STi is a much larger diameter. Thats why you need to put in svx front diff seals so the seal matches the stub. Otherwise you could very well leak front diff oil out quickly enough to cook your uber expensive transmission.
Tom |
#88
please tell me that can be done with the trans in...
#89
i know you can on the rest of EJ trans... if that is any relief
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
#90
So I now need the side plates from a 4EAT???? OT or YT????? and if so how much?
