Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Supercharged Projects
Old 12-22-2008, 09:04 AM
sicksubie's Avatar
Sicksubie's S/C set up
7/24/10 Update: I have been rehabbing a house in my spare time so the SVX has been neglected for a while now. The house however is nearing completion and there will be more and more free time to spend on it.
Currently:
The car:
For those who do not know my silver car was destroyed by 3 trees that fell on it during the ice storm in December of 2008. It has since been a year+ process of transplanting everything over to the SVX. It was originally an ebony, but has since been painted (almost finished) in House of Kolors Black Pearl...
The motor:
- CP forged pistons with 8.5:1 CR
- Eagle H-Beam rods
- ACL Bearings
- ECUTune valvetrain with SS intake valves and Iconel exhaust valves
- ECUTune intake and exhaust cams
- Polished intake stacks
- Ported Exhaust openings
- Outlaw Engineering phenolic spacers between the heads and the intake stacks and also between the blower and the manifold
- Nismo 740cc injectors
- Whipple 1600AX supercharger
- Coolingmist methanol injection kit (using their larger jet and injecting pre-blower)
- Group N motor mounts
- Equal length headers going to a dual 2.5" exhaust
- Twin shorty intakes
The drivetrain:
- Full 2007 STi swap
- 6 speed transmission
- Stock STi flywheel and clutch
- R180 rear differential
- STi rear axles
- SVX front axles
- 6 speed swap kit from YT
- Kart Boy short shifter from Turn in Concepts
- Turn in Concepts Holy Shift kit (replaces all shifter bushings)
The brakes and suspension:
- Stock calipers
- Slotted rotors from Race Concepts
- SS lines
- Axis Ceramic pads
- Koni/ Ground Control coilovers with 415lb springs in the front and 385lb rears
- $15/ 15 minute mod
- $20/ 20 minute mod
- Urethane rear swaybar bushings
Wheels/ Tires/ Miscellaneous:
- BBS 17x8 powdercoated gunmetal (Stock 2006 STi wheels)
- Bridgestone Potenza RE-070 225/40/17
- 5k HID's from Old Tom
- Sparco drivers seat
- Scroth 4 point harness
- Stripped trunk, removed rear seat belts, moved battery to trunk
Coming up:
I ordered camber plates from K-MAC
R888's in 255/35/18
18"RPF1's
Front seats
Figuring out the front brakes and what route to go with them...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 12-22-2008, 09:13 AM
sicksubie's Avatar
What is in the works...
The start of it all... The car getting towed down to All We'll Drive to install the motor Tom built as well as the supercharger from ECUTune.
Old motor out
Built motor in
Blower outlet with custom made spacer by Outlaw Engineering
Finished
First auto-x in the car and this happened
I ended up driving it that way all the way to Cumberland MD where swapped out driveshafts at Old Tom's 20 minutes before the first runs at the 2007 Pumpkin Carve Meet.
I was still on 150k old suspension and transmission at this point and knew my time was short in both areas before they gave up the ghost.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-22-2008, 09:14 AM
sicksubie's Avatar
6 Spd swap and coilovers
Thumbs down
2007 STi Trans with 9k miles
R180 rear diff
Kart Boy SS and Holy Shift kit from Turn in Concepts
Thumbs up
Old suspension out
New suspension in
Thanks to:
Young Tom.....
Old Tom.....
Mike (ECUTune....
Clint (Turn in Concepts)
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-23-2008, 07:47 AM
longassname's Avatar
Just some dude.
Significant Technical Input
Re: Sicksubie's S/C set up
ouch, poor car. Those ice storms are a real problem down here too
Old 12-23-2008, 10:03 AM
sicksubie's Avatar
Shut up... Just watch out for the hurricanes down in FL... lol
The new car getting the transplant
Getting seam welded
Ready for body work
Ready for paint
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-23-2008, 08:40 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Originally Posted by sicksubie View Post
Shut up... just please shut up... Hey I may be coming to FL in March for the Red Sox spring training... Just need to watch out for hurricanes.
I think you had him at "hello"?
Dustin
-Dustin
Old 12-24-2008, 11:54 PM
Nevin's Avatar
Nevin Nevin is offline
Yeah, I hate to admit, but I would much rather have ice than hurricanes.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 08-20-2009, 01:31 PM
sicksubie's Avatar
The car has been completely transplanted into a 1992 ebony... The body work is all done and it heads to paint on Sunday. I finally got my laptop to interface with my laptop so fingers crossed I start the car for the first time in 10 months tonight...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-20-2009, 05:36 PM
Re: Thanks to....
Young Tom.....
Old Tom.....
Mike....
I just now saw this Bobby, Thanks!
BTW, Which Tom am I again?????
Old 03-12-2010, 08:00 PM
sicksubie's Avatar
These came today... My dual intakes are now complete.
Tonight I started mocking up the alternator where the AC compressor used to be, worked on mounting the 11.5lb Braille battery in the engine bay, and started fitting the methanol reservoir where the ABS unit used to be...
I also got a new power steering pulley in the mail yesterday from LAN to replace the warped one, that will get installed tomorrow.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 03-12-2010, 08:29 PM
92 SVX 92 SVX is offline
You got a pic of the dual intake setup on the car? Would be very cool to see.
Old 03-12-2010, 08:45 PM
sicksubie's Avatar
Those 135 degree silicone hoses are the entire intake. I am not running the piping all the way to the fender wells, but rather going for as short an intake length as possible. I have a massive Green air filter for the end of each of the hoses. I am not overly concerned with under hood temps as the hood will be well vented.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 03-12-2010, 10:51 PM
Interesting, dual MAF's? Special tuned ECU?
Old 03-13-2010, 03:45 AM
Pure_Insanity8's Avatar
Pure_Insanity8 Pure_Insanity8 is offline
Send a message via ICQ to Pure_Insanity8 Send a message via AIM to Pure_Insanity8
I can't believe I didn't see your update before... I literally searched for it not too long ago. I was nearly as heartbroken by what happened as if it were my own car. Glad to see things are coming along (you're basically building what I've wanted mine to be since '98). Deffinately keep us updated.
-Aaron
SVX: '92 Dark Teal 101k
'97 Legacy GT Wagon: dead
'99 Civic Si: daily driver... stolen and stripped with all my tools!
'92 Yamaha FZR 600: garage
2011 Jetta: Daily disappointment
Old 03-13-2010, 04:30 AM
Nice going Bobby.
When the world sends you lemons, make some lemonade.
