Hydra EMS Nemesis II ver. 2.7 RELEASED
Ok so as promised here is the breakdown of the new Ver. 2.7 of Hydra EMS Software and Hardware. As far as when I will start selling them, I'm going to get one in here probably in the next month and start to play around with it and see how it differs from 2.6 so that I can better support those of you who decide to purchase. Also we should still be able to trade in any 2.6 EMS for a Stage III 2.7 Working on IRIS support and VE Maps, VE Base Map will be the only base map that will cost.
Pricing: Hydra Nemesis: Pricing broken down by stage, see below Base Maps: $0 (currently offering for free with purchase, 2 maps, one from Element, and Tom's original 2.6 map converted to 2.7) Torque Control harness upgrade and Map: $50 (not currently offered) Wideband Sensor and Harness: NTK L2H2 kit for $450 extra, and their standard kit for $260 AIT(Air Intake Temp) Sensor and Harness:~$99.95(in development) Hydra 2.7 Specs and breakdown The Hydra2.7 has complete new firmware and software along with new processor with onboard datalogging and new idle, boost control, aux map and long term trim strategies. The 2.7 will also have capability to configure for additional sensors as inputs with configurability. Stage5 Epsilon has built in CAN Bus for use with external dashes, so you can run a dash and tune at same time. Hydra2.7 will be firmware upgradeable remotely without sending the ecu back. Each stage will be upgradeable to the next remotely without sending the ecu back. You can also just buy individual Capabilities if you do not want the next full stage upgrade. Stage 1 Alpha and Stage 2 Beta will be stripped down versions with fewer outputs and inputs then the current Hydra2.5 and 2.6. To get equivalent Outputs as the Hydra2.6, you will at least need the Stage 3 Gamma upgrade Alpha Stage 1(would need to be upgraded slightly to work with the SVX) $1350(OBD1) $1450(OBDII) • 4 injector • 2 inputs,( 1 analogue and 1 digital) • 6 outputs • Knock control • Internal Datalogging Fixed 8 channels Beta Stage 2 $1500(OBDI) $1600(OBDII) • 6 injector • 6 inputs(4 analogue, 2 digital) • 9 outputs • Aux Fuel/Ignition Map • Launch Control • Intake VCT Control • lambda Target • Tip-in Enrichment • injector phasing • Basic boost Control • Staged Injection • Internal Datalogging Fixed 8 channels • Internal Wideband Logging Gamma Stage 3 (equivalent to ver 2.6) $1700(OBDI) $1800(OBDII) • 8 Injectors • 10 inputs (4 analogue, 6 digital) • 14 outputs • Knock control • Aux Fuel/Ignition Map • Launch Control • Intake VCT Control • lambda Target • Tip-in Enrichment • injector phasing • Basic boost Control • Staged Injection • Internal Wideband Logging • Antilag Fuel /Ignition Map • Exhaust VCT • Immobilizer request • Valet Request • Flat Shift • Alternator Control • VE Mode • Alpha N Mode • Boost Compensation • Gear Correction • Individual Fuel and Ignition Trim • STT Ignition Trim • Throttle derivative • 3D maps • Manifold Pressure delta trim • Internal Datalogging Configurable 8 channels Delta Stage 4 $1800 (OBDI) $1900 (OBDII) • 8 Injectors • 10 inputs (4 Analogue, 6 Digital) • 14 outputs • Knock control • Aux Fuel/Ignition Map • Launch Control • Intake VCT Control • lambda Target • Tip-in Enrichment • injector phasing • Basic boost Control • Staged Injection • Internal Wideband Logging • Antilag Fuel /Ignition Map • Exhaust VCT • Immobilizer request • Valet Request • Flat Shift • Alternator Control • VE Mode • Alpha N Mode • Boost Compensation • Gear Correction • Individual Fuel and Ignition Trim • STT Ignition Trim • Throttle derivative • 3D maps • Manifold Pressure delta trim • Internal Datalogging Configurable 8 channels • Steering Load • Traction Control • Coolant Temp RPM Trim • External Map sensor • Engine Speed Delta Trim • Idle speed Error Trim • Calibration Input Maps • Fuel Pressure correction • TPS Position Trim • Barometric Compensation • Fuel Temperature Compensation Epsilon Stage 5 $2000(OBDI) $2100(OBDII) • 8 Injectors • 10 inputs (4 Analogue, 6 Digital) • 14 outputs • Knock control • Aux Fuel/Ignition Map • Launch Control • Intake VCT Control • lambda Target • Tip-in Enrichment • injector phasing • Basic boost Control • Staged Injection • Internal Wideband Logging • Antilag Fuel /Ignition Map • Exhaust VCT • Immobilizer request • Valet Request • Flat Shift • Alternator Control • VE Mode • Alpha N Mode • Boost Compensation • Gear Correction • Individual Fuel and Ignition Trim • STT Ignition Trim • Throttle derivative • 3D maps • Manifold Pressure delta trim • Internal Datalogging Configurable 8 channels • Steering Load • Traction Control • Coolant Temp RPM Trim • External Map sensor • Engine Speed Delta Trim • Idle speed Error Trim • Calibration Input Maps • Fuel Pressure correction • TPS Position Trim • Barometric Compensation • Fuel Temperature Compensation • On Board CANBUS Control( for CAN expansion Box and Dash Support) • Two Internal feedback outputs • Humidity Correction • EGT Correction(requires CAN Expansion Box) • Flex Fuel Support • External Wideband Support • Vehicle Speed Pit Limiter Optional Capabilities • Sensor Calibration maps • Advanced Output Configurations Last edited by Johnybeas; 01-22-2014 at 08:04 PM. Reason: pricing and info update |
Re: Hydra EMS Nemesis II ver. 2.7 RELEASED
Geezus!!!!!
I'm glad this option isn't dead.
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
definitely far from dead and more maps soon to come for those who have modified their SVX with bolt ons such as intake, exhaust, headers etc
bump... anyone want the best engine management out there??
where do i get one of these
Give me a call we can order one in for you (801)948-0877
New maps available and new harness has been updated to include IRIS functionality directly out of the box. VE Stage II and Stage III maps will be getting designed in the next few months.
Until this guy makes good on the intakes, it would not be wise to give him any money.
It is not listed on their site, but Phil Grabow at Element Tuning is also able to get the hydra for the SVX. He will be tuning mine this spring so I can dial in the supercharger perfectly.
