Electric Turbo Charger
I've had this idea for a while and just found a company that makes an electric turbocharger.
http://www.electricchargers.com/ While there product looks like a POS, it almost has to be for $100, I think it's a pretty sound idea. It's not as efficient as using exhaust has or being belt driven but it's a whole lot easier to install and should be a whole lot cheaper. Has anyone seen this before or have any information on a quality electric supercharger? |
no wait,
Brian Last edited by Ricochet; 03-12-2007 at 08:55 AM. |
garbage. I cant believe people still buy into that ****.
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
Do you have reasoning for that? |
That tiny fan cannot create any actual "pressure", i would go as far as to say it's more of a restriction, because the engine will draw air in faster than the motor can spin the tiny fan. The only practical electric super-charger i have seen is by Thomas Knight, on a nissan altima. He had to have 6 special batteries and 3 rediculiously complex blowers. It worked, only as long as the batteries could sustain it. Once they ran out, it did not work. The alternator could not produce enough current to keep them going at all times, so he installed a switch for it. You can read the article here: http://www.turbomagazine.com/tech/04..._supercharger/ Nothing for under 2000+$ will give you any performance boost, unless you build hte parts yourself, by hand, but then you pay for it in hours of labor. In short, you get what you pay for.
on a .8l engine it might have those kinds of gains... on a 3.3l that already breaths deep, it is merely a restriction
Tom |
If you get an upgraded alternator you can have as much as 1200 Watts of extra power (100 amps extra x 12 Volts) when accelerating, that's enough to drive a pretty powerfull vacuum. Now take that power and direct it into the air intake and I could certainly see a significant power gain.
As I already stated that $100 thing is a POS, but that doesn't mean that something similar couldn't work. |
Reminds me of the leafblower mod
Might make a difference to my Taurus, which was factory tuned with a 10 pound sledgehammer (a whopping 145 HP out of 3L), but not to a better engine.
My turbo spins at 23,000RPM. the HEAT created from compressing air would melt the plastic blades on that fan, and would most definetly melt the maf. phil
