Old 09-17-2008, 04:01 PM
AUSVX AUSVX is offline
Registered Loser
Rear window interior panel
Hey everyone, when I first got my SVX I thought that the rear interor trim had just warped in the sun over time, it was really sticking out off the window and both rear window trims were sticking out BUT while I was in the back seat yesterday I realised that someone had taken off the trim previously on the LH and RH side (against the window).
When they put the trim back on they must have just smashed the panel in and thought they did a good job BUT when I pull the panel back and peak inside I can see the clips are bent up and not in their holes.
I'm gonna upload pictures tonight but in the mean time, I was hoping there was a How-To for taking the whole panel off to access the window???
If anyone has any instructions on how to take the rear trim off, help would be much appreciated.
Thanks, Jordan.
Old 09-17-2008, 06:30 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Rear window interior panel
If you mean the piller trim pieces then they are just clipped in.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-18-2008, 02:49 AM
Registered Loser
Nah it's not the pillar trim piece it's the piece that covers the rear window motors
Still need to take photos but it'd be great if anyone knows or has any suggestions
Thanks, Jordan.
Old 09-18-2008, 07:09 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
IIRC You have to take the rear seat base out first.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 09-18-2008, 02:05 PM
Francis Francis is offline
i've done it with my old svx "for amplifier power cable"...its a pain in the ass, tip : take your time
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Old 09-18-2008, 02:09 PM
Remove the seat bottom (there's two plastic dealies at the front edge that you have to wiggle), then there's two plastic screw things in each side, one against the floor and one through the side. Those have to come out (small philips screwdriver and something thin to pry with). Once those are out you should be able to pull the panels off. It may help to remove the seat back. If you want to do that first remove the row of bolts holding the trunk carpet to the seat, then at the bottom rear corner the fabric is velcro'd down. Pull it up and you will see two bolts. Remove those and the seat comes out.
You'll be amazed what you'll find hiding in there. It was a mini-lottery for me.
