Old 03-31-2009, 08:41 PM
mo_thug_85 mo_thug_85 is offline
any one know about the 2.2l subaru engine
my dad bent a valve in his 97 leg.
my friend has a head for a 96 leg.
will the 96 work?
Old 03-31-2009, 09:03 PM
Re: any one know about the 2.2l subaru engine
Arrr double post. Bad juju.
I don't know if it'll work...The engine was changed slightly from 96 to 97, and one of the changes was to the valvetrain. If he has two heads you might be able to put both on and make a hybrid engine.
Old 03-31-2009, 09:12 PM
ok well i was going to get both heads. and i posted in the wrong place the 1st time
Old 03-31-2009, 09:44 PM
taylorbr's Avatar
taylorbr taylorbr is offline
Pretty sure that's the 2.5l, the 2.2l was used on the first gen legacys.
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 03-31-2009, 11:37 PM
I deleted the other post for you. Please keep it to one.
Old 04-01-2009, 11:51 AM
paulmeisterpk's Avatar
paulmeisterpk paulmeisterpk is offline
Sconnie
Send a message via MSN to paulmeisterpk
Although the 96 and 97 are both 2.2L SOHC with single port exhaust, the 96 is a non-interference engine, and the 97 is an interference engine, so I think they must have changed head designs, and probably piston designs. I'll check some part numbers for you if I can.
Old 04-01-2009, 12:03 PM
Sconnie
So I checked on 96 2.2L vs 97 2.2L out of Impreza Outbacks, which should be the same engine that they put in the Legacies those years, and the part numbers for the heads for those two years are different. I am not sure what the differences are, but they are not the same heads.
Old 04-01-2009, 05:35 PM
Manarius's Avatar
Manarius Manarius is offline
Nah, the 2.2 showed up in some form all the way until 1999. However, the ones made for MY97 and later have redesigned piston crowns which means that they are now interference engines. Also, mid 1996 or so, EJ22's started having solid lifters, not HLA's like the previous EJ22 and EG33.
-Jason
-Obi Wan Kenobi
Old 04-01-2009, 08:42 PM
The earlier style 2.2 heads look ENTIRELY different than the later 2.2 heads, so if the other head "Looks" like his original head, I say it'll work fine.
Old 04-01-2009, 08:43 PM
svxpert svxpert is offline
<<my dad bent a valve in his 97 leg.>>
care to elaborate?
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it.
Old 04-01-2009, 08:55 PM
Green1995SVX's Avatar
care to elaborate?
Based on his previous posts, I doubt that's a possibility.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-01-2009, 08:56 PM
care to elaborate?
97 is interference... I am guessing broken timing belt.
The big difference is in the exhaust ports. dual or single port. Either will work but make sure you have the right set of head pipes. I personally would use the cams and lifters out of the original engine just for safe measure
Old 04-02-2009, 12:22 AM
Hondasucks's Avatar
Subaru Technician
The stage 2 EJ22 looks just like a single cam EJ25, and is an interference motor. I am not sure when it started appearing, I think it was late production 97, since my friend has a 97 OBS that has the "old style" EJ22 in it. If both engines look identical, then yes it will swap. The newer style heads should, in theory, be interchangeable, but I do not know for sure since I've never had the two apart side-by-side to compare.
1986 VW Jetta
