Engine misfire on cylinders 1&2
Anyone please help im at wits end with this subaru its the 1st subaru that I have ever had any trouble with. We bouth the car and it was sitting for a year, my grandfather put new 91 octane in it with the 1/8 tank of old fuel. I told him not too but he is stubborn. The car never has run great one day and every since its been horrible. I have to have transportation to ER(work). CEL is on for misfire in cylinder 1 and 2
We pulled plugs checked compression= all cylinders above 180psi = good Changed out plugs Replaced all the vacume lines Replaced the ECU Ran sea foam in full tank 0f 91 octane Even had a subaru technician some out and he ran subaru engine cleaner, adjusted all the idle controls and hooked it to a computer. I was running sooo smooth and great Today we unhooked battery to replacxe wiring for the altenator, after starting it up its back to the same issues and now its sounds like its back firing only under load and going uphill. Ive about had it... I still love Subarus but Ive about to be drained dry with this one. If anyone has any suggestions please let me know I would appriciate it greatly Thanks! _Tyler |
Re: Engine misfire on cylinders 1&2
Did you check your coils?
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
yes I checked them they seemed to measure within specs a little on the lower sode but within specs and we just replaced all injectors
You say you checked the coils, i guess you used a multimeter. You really need to check the coil boot and the surface of the coil for spark tracks that will short out the spark under load. Look for a black track that runs down the side of the coil from the plug end. If you find one, just scratch the track out with a small pointed scribe, and spray with a silicon oil spray. Harvey.
Timing belt could have slipped. Remove the cover and see if any shredded belt is visible.
