Old 05-10-2012, 05:56 PM
Re: Its Finally Time, and looking for tips
Originally Posted by VICSVX View Post
good thread, i am about to tear into mine @202k and trans R&R..
so as i take it,
seal kit
oil pump
mounts
VAC lines
timing belt and pullys
anything else i am missing....anyone have prices/part numbers for all this?
Water pump. Get an OEM water pump. Timing belt and idler pulleys get off Ebay. Vac lines I'd get some bulk silicone vac line from Ebay, since it's pretty cheap. 1/8" and 3/8" ID if I remember correctly.
Old 05-10-2012, 06:48 PM
92 SVX 92 SVX is offline
May not hurt to get a few feet of 1/2" for the aux Idle control.
Old 05-11-2012, 10:34 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Sweetness, thanks for the help guys
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 06-20-2012, 04:31 PM
nsm484's Avatar
nsm484 nsm484 is offline
Teh Geek
Send a message via ICQ to nsm484 Send a message via AIM to nsm484 Send a message via Yahoo to nsm484
Ok, it seems I cannot rebuilt the engine in my 96 with my budget, because the head gasket break allowed water to run back into one cylinder, and caused a nice big pit.
So, I am going to take the engine from Yori, my 92, and put it into my 96.
Now... I have a question for anyone who may know.
Is there anything I have to swap out, etc, to get my 92 engine, to work on the 96 ODBII ECU?
Or am I going to have no problem at all just slapping it into my 96?
Thanks in Advance for any advice!
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker
2002 Mitsubishi Lancer OZ Rally [Nori]
1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling
1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone)
1992 LSL Ebony Mica (Sold to svxcuseme)
Old 06-20-2012, 04:55 PM
Roger, the only real difference is the addition of the EGR temp sensor on 94+ engines as well as the relocation of a solenoid from under the intake manifold to the strut tower on OBD2 cars (96+97), so the best bet will simply be to swap intake manifolds and upper engine harness from the 96 engine to the 92 engine. These are the only differences.
Also, to note, don't throw oout that engine block. It can be bored and fitted with oversized pistons, rings, head gaskets, etc and still be usable. Someone planning a complete teardown could be interested.
Old 06-20-2012, 05:59 PM
Also if you have not checked yet there was a complete SVX in Howell's Auto yard over on normandy blvd maybe that engine is still good?
Old 06-20-2012, 07:36 PM
nsm484's Avatar
Teh Geek
Awesome. That will make life easier knowing that, and its simple. Thanks 1986nate
Indeed. Everything I have left over, I will be offering on the forums.
I will, after this, have the engine parts from the 96 engine, and the shell from the 92.
I haven't checked, but givin that the body damage to Yori this seems like the cheapest option I have right now
P.S. I am sorry I haven't called you over to help, when it happened, it was a rush deal in the since of me getting pulled in a million directions at once.
We will be starting on the swap Sunday if you want to come over, help out, or just hang out with the crew
Old 06-20-2012, 11:34 PM
Sounds good, give me a call or text with the address sunday
Old 07-03-2012, 11:59 AM
nsm484's Avatar
Teh Geek
Yesterday we finally got the car running, after all the bad weather stopping us, she is finally running again!
I will say, using Impreza 1.8L Motor Mounts are a PITA, but they do work if you can wedge them in there. The engine sits a little farther forward and up, but not too much.
While that engine was in the 92, it didn't run the greatest, but now that its in the 96, and all the vacuum lines are replaced, she purrs.
The trans also shifts great for sitting so long, nice and smooth shifts.
The tires need some work, but I expected that.
However.....
Now I either have a Power Steering Line, or the rack itself, is leaking on the exhaust, and she smokes like crazy.
So that will be the next thing I try to track down. But, at least Calista is back on the road again.
I also started a thread for parting out Yori, see signature
Old 07-03-2012, 04:15 PM
kjoyes kjoyes is offline
run a couple of tanks of gas threw her to see if the problems will work there way out of her.
