Old 02-07-2009, 01:11 PM
karmaken karmaken is offline
Send a message via AIM to karmaken
power steering hose leak
I have replaced my power steering pump on my 94 svx LS front wheel drive unit. I am now suffering a very nice old faithful type leak on the long hose coming up to the pump from the back part of the motor (is this the return line?)
I need to replace the hose. I tried to noodle the hose thru rock auto but they have specific lengths. With out removing the hose, does anyone know what hose I need to order and then, the best place to order it from? And then, once I get the hose, how hard is it to replace? looks like the spot where it connects underneath is tight to get to.`
I love this car and have missed driving it. Any help would be greatly appreciated!
regards
ken
1994 Subaru svx
1994 Toyota Previa
1964 Lincoln Continental Convertible
Old 02-07-2009, 01:45 PM
kwren's Avatar
kwren kwren is offline
Re: power steering hose leak
Is it the hi pressure hose or the lo presure?
lo presure would just be a matter of getting hose that is made for that and sizing it yourself.
I think that one hose fastens on the pump with a hose clamp ( the return ) and the other ( High pressure) is done with metal fittings.
Guess the first step is to find out what is actually leaking.
Maybe the "O" ring on the bottom of the pump reservoir?
Hope it works out well for you!
Keith
Old 02-07-2009, 01:46 PM
Green1995SVX's Avatar
regards
ken
That's your high pressure hose. Subaru part number 34610PA120. It'll cost you $113.92 from your local dealership. When the hose went bad on my 97 SVX, I had a local hydraulic shop make me a replacement. It was only about $50.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 02-07-2009, 03:19 PM
$86.80 plus shipping, subaruparts.com
Old 02-07-2009, 08:49 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
You could get a rebuilt one for cheaper.. ask a mechanic or something..
Old 02-08-2009, 07:58 PM
Thanks for the replies. Its definitely the high pressure return. I was able to band aid the line with some metal tape and 4 hose clamps. No longer is old faithful in session. I know its temporary. I need to trace the line and see where it mounts underneath. It looks like a tight fit. Anyone ever remove one? Did you need to remove any additional parts for access?
regards
ken
1994 Subaru svx
1994 Toyota Previa
Old 02-08-2009, 08:09 PM
My car doesn't have that hose..... Not in that location anyway.
Old 02-09-2009, 10:49 AM
paulmeisterpk's Avatar
paulmeisterpk paulmeisterpk is offline
Sconnie
Send a message via MSN to paulmeisterpk
regards
ken
That is the high pressure hose. I replaced mine a year and a half ago after I ordered one from subaruparts.com. It was a tight fit. I think I removed the plastic air intake parts and that was it.
Old 02-09-2009, 03:52 PM
The easiest way to reach the bottom fitting is to remove the right front wheel and have at it from the bottom of the car. The hose is fixed to the body of the car with one bolt down there, and is attached to the rack with a standard fitting. It's pretty straight forward. You'll need a flashlight and someone to hold it, too.
Make sure to support the car with a jack stand, especially if you have your legs under there.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 02-09-2009, 03:53 PM
The hose runs down and along the bottom of the engine in older (92) models. The hose is there, just in a different location from the newer ones.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 02-09-2009, 04:23 PM
Ah, gotcha. Thanks.
Old 02-10-2009, 07:28 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Yes,the hose runs down and along the bottom of the engine in older (92) models and is in two pieces. The newer models is a one piece hose that runs on top of the engine. You can order either one from Subaru but I replaced my old one with the newer one. Less connections, the better.
Old 03-01-2009, 10:00 PM
Bshade's Avatar
Bshade Bshade is offline
Send a message via AIM to Bshade
Ok I have a 92 that I just lost all power steering and I knew that there was trouble with the high pressure hose so I came here to find out. So what I want to know is should I replace it with one hose or two like stock. there is a local shop that can remake it for me in SS wrap as I had him make me a few brake lines and few other lines already. but I don't know what the one piece hose should look like.
Brad the Superlative!
1988 Firebird Trans AM, 1987 BMW 325is,
1978 Dodge RamCharger, 1989 Chrysler Conquest,(2)
1988 Merkur XR4TI 1973 Super beetle Baja Bug
2006 Chrysler 300C SRT8 1996 Buell S1 Lightning
1998 Subaru Forester 1993 Chevy K2500
Old 03-02-2009, 12:44 AM
kwren's Avatar
Personally I would go with the one hose replacement.
Just my 2c worth
Keith
Old 03-02-2009, 06:29 PM
Bshade's Avatar
Well here in Lancaster we had about 8 inches where I live so I took the SVX up to my shop to work on it. I jacked it up and crawled under wile power steering, oil, and salty melting snow dripped on me. I started to remove the high pressure line when I notice a low pressure return line had come completely off. It was the one right beside the high pressure feed, the rubber hose had popped off the metal line. So I proceeded to not take apart the line I did not need to I and put the low pressure back in place and installed a new hose clap. I could find nothing wrong with the old one but I threw it out in spite anyway. So long story short I got the car up and running again with ease this time.
