big overhaull
hello people!
today, it's my first day of vacation i have all parts to overhaull my dear svx so about the work, we doing : - timming belt replacement - A/C belt replacement - ACC belt replacement - sparks replacement - air / fuel / oil filter replacement - cooling fluid / engine oil / power steering oil replacement - somes stupid parts so let's do this! |
Re: big overhaull
If you're lucky, you will only use one day of your vacation to do this...
and enjoy the rest of your vacation driving your svx and enjoying the fruits of your labor. .
Re: big overhaull
1st day :
first, remove engine undercover and both 2 upper covers. remove battery from the car and the plastic thing bellow the battery. after do that, remove the down hose of the radiator. cooling fluid comes out so put something to keep it and discard it. remove the upper hose and the hose coming from to the cooling fluid canister. cooling fluid comes out so put something to keep it and discard it too. now, remove the 2 littles hoses at the lower of the radiator ( it's probably gearbox oil fluid ) fluid comes out so put something to keep it and discard it. you can disconect fans, remove the upper brackets and pull out the radiator assy whit fans. you can remove the front grill to have more access ( 2 clips at upper ) and you going like this : now, you can loose the nuts of the power steering belt thighter. ( 1 nut and the screw ) that can loose the belt and you can remove it. mine was in very bad condition! now loose the 2 nuts of the A/C blet tighter. ( 2 nuts ) that can loose the belt and you can remove it. not really nice condition too. now, you can remove the 2 tighter brakets. 3 bolt of the A/C one and 1 nut for the steering one. disconnect the hose of the power steering pump. the hose pass just in front of the right side of the engine. doing that give you more space to check the timming belt of the right side of the engine. look out from the leaking fluid! thats all for today! tomorow i'll go remove alternator and power steering pump and remove timming belt covers. see you tomorow! Last edited by Naru; 03-29-2010 at 10:10 AM. |
Re: big overhaull
Wow, needs a good cleaning. Make sure you get lots of nice "after" shots!
Re: big overhaull
yeah.
this car is old and not realy good maintenance. i'll gonna clean all before reinstall all of the parts. and you know, the black dust on the engine is from? its from steering belt! scary!!! lol |
Re: big overhaull
I had some issue when I first got my svx where it kept eating my power steering and a/c belts. It was so bad that I needed a new belt every week. Eventually, I got some money and OT fixed the problem for me. The belts beat the crap out of my hood though.
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
Re: big overhaull
OT ?
