#151
Re: 11:1 Engine Rebuild
Nah man, grainy cell phone vids poorly uploaded to youtube will more than suffice
#152
maybe tomorrow
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
#153
Took her for a drive. Couple of noises that need worked out under the hood.
At first she was overheating...had not done it before, but I had only let her run 20 minutes this morning. I decided to take her around the block and try to gauge whether air through the radiator would make a difference. The air in the car at this point was VERY COLD. She was overheating but the heat would not work in the car. I was very confused. Taking her out for a drive worked, though. I believe the heater core was empty and possibly had to take on fluid to make the air warm. Not sure how the heater core works exactly, so that is just a guess. Also, I think I just had some air bubbles in the coolant, that worked their way out. She leveled out and then the problem did not persist. She drove great, by the way. But the power steering pump is sounding very bad. It is "grinding" instead of being quiet. Gets worse with RPM's. So I will be replacing that very shortly. Also, I have a spare power steering rack at my parents house. Once I clean the garage rebuilding the rack will make a nice project. Anyone have a list of all the seals and parts that will need replaced for that? And I saw a list on here for the power steering pump rebuild, but would that take away the grinding noise coming from the pump? It sounds like a bearing to me, but I suppose it could be hard parts. The pump is making turns "pulse" from the power steering, so it's pretty damn annoying.
#154
Try flushing the PS fluid first. If it worked ok before it sat for all those months then it might work itself out.
Congrats on getting it going though. Isn't that first drive so great
#155
Well she ran dry for a bit...definately not a good thing. I was being stupid, and forgot to connect a hose after my little oil incident. She still works for the time being, just not perfectly.
#156
As for the overheating and having no heat, you still have air in the system. How did you go about pouring coolant into the system?
#157
It burped I filled the block through the upper radiator hose, then the radiator, then started the car and filled the overflow while she ran. No more problems there. I figured it was just air. The p/s pump quit making noise and is back to normal. I adjusted the tps and had the tranny drained and refilled. She is being spoiled.
Still having some idle issues. Could be a vaccuum leak I suppose, but it is acting like the maf. I will diagnose that tonight and try cleaning it. Coincidentally the only valves not replaced on the engine were egr and iac. The iac could cause the issue I suppose. She idles a little rough once she's warm, and sometimes falls low enough to stall. Idle is bouncy also. When cold she is bouncy but does not die, because she is high enough in rpms. It also seems like shes a little rich in the lower rpm's. She does run VERY well, other than the small stuff. Input?
#158
Each problem is slowly resolving itself. Most of it is probably the stock ECU freaking out
She still dies at idle if I rev it up and let off the gas completely. Could be the throttle body needs a cleaning and adjusting. Could just be me overanalyzing everything. I will make it a point to do my valve body upgrade, and TCU upgrade so I can safely do my injectors and MAF and ECU. Then she will make the real power. I am sure I am maxing out the MAF, but the MAF can only handle just above stock power. She surely has MUCH more torque down low. She feels as if she needs more fuel to truly shine, though. Ill keep you guys posted
#159
Congrats on getting it up and going... What cams do you have in there?
Tom |
#160
Thanks Tom!
256 duration intake/exhaust with 8.1mm of lift from ECUtune.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted Last edited by Cam; 01-29-2011 at 01:32 PM. |
#161
Those are the reason it stalls. Gonna need to manually adjust the IAC open further. Also might want to bypass the secondary IAC and use a manual valve if the first option doesn't help it keep the idle up. Those cams drop the manifold vac. too much to use the stock settings and let it idle
Tom |
#162
Which one is the primary and secondary?
#163
Cam, can you take some very detailed pics showing what it is you do with the IAC to make it work with the cams? Thanks bro
#164
I will be sure to do that. No problem there. We will see if it works, I am gonna dig around a little later and try to diagnose the issues I am having before making any adjustments. I am positive I have a vaccuum leak and I think that removing the charcoal canister is having ill effects. She runs better with the lines to the canister open rather than bridged. Still expirementing a little.
#165
That could just be because the line being open allows in more air in past the throttle bodies. Same effect as opening the IAC more would have.
