Timing belt time?
10 characters.
Re: Timing belt time?
Svxfiles replaced the timing belt (and all idler pulleys, etc) on my 1996 Polo about a month ago, along with water pump, oil pump, all new seals and gaskets.
The car had the original timing belt on it (12 years old) and 122,000 miles on it at the time it was changed. When we pulled off the old belt and compared it to a brand new OEM one, you couldn't tell the difference. There was no cracking, crazing, dryness or wear on the old belt. All of the guide markings and numbers were as clear and bright as on the new one we put in. I still have the old one as it is in remarkable condition. Tom said I could save a little money by just putting the old belt back on and buttoning it up. You can pull off the timing belt covers to check the condition of the belt. In my case, there would be no way to know how old the belt was if I had just gotten the car. I bought mine at 42,000 miles, so I know it was original. Just replace it (and the water pump too) and forget about it for 100,000 miles or so. California law requires that timing belts last 105,000 miles, so I am sure that you may never need to change it again. I'll take some good photos so you can see what a 120,000+ belt looks like. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 12-12-2008 at 12:09 AM. |
10 characters.
I replaced mine this summer and likewise, it looked in excellent condition. The print had been mostly worn off, but otherwise there was no indication that it was 16 years old with ~120K miles. (I'm about 75% on it being original)
