[WANTED] Rear spoiler
Hi,
I'm wanting to buy a US black spoiler for my '94 Subaru SVX, thanks ! Mail : pierre-olivier83@hotmail.com |
Re: [WANTED] Rear spoiler
Hi; I have one, $75.00- plus the cost of shipping; Partstogo@gmail.com
Dan sr. |
I'm looking for one as well. How hard is it to drill the holes for proper installation? I'm worried it'd be easy to get crooked. Also do you need to take any rust proofing measures to keep the trunk from rusting from water getting in the drilled holes?
I would think it would just be a safer bet to buy the entire trunk assembly with spoiler. Seems like the safest route to go and if for whatever reason you want to go back to spoilerless then just swap trunks...
1994 subaru svx le 112k |
It is extremely easy. The underside of the trunk has reinforcements where the bolts for the spoiler go, which are square (ish?). Just drill into the middle of them and you're good to go.
In addition the mounting holes in the lid for the spoiler are outside the rubber seal where the lid meets the trunk opening. Because the spoiler is an option... there are 4 small mounting points molded into the underside fiberglass trunk lid... so drilling is a no brainer. |
Actually, there is no pre-formed gasket between the spoiler and the trunk lid. What is used is a thin strip of rope caulking. This is available at most body shops or parts stores. Roll a thin strip between the palm of you hands, and completely surround the two mounting studs on the spoiler, pressing it lightly into place. When you bolt the spoiler in place, the rope caulk compresses and forms a waterproof seal. .
Sorry Pierre but I am going to semi-hijack your thread.
Does anyone have a US Polo Green spoiler in very good condition? Mine is getting pretty nasty and it may be cheaper to buy one than get it painted.
The paint on the spoilers is typically the first to go. They were actually painted and installed at the port in the US, and the paint is of substandard quality. You'll be hard pressed to find a spoiler with nice looking paint. When I bought my green 95 SVX, it was only about 4 or 5 years old at the time, and the spoiler's paint was already peeling.
Do you have the JDM style wing now, or are you wingless? I'm curious, may be willing to give ya the one I have spare from Nate (thanks again bro! ).
Re: [WANTED] Transmission automatic - SVX 1994
Hello, i'm looking for a automatic transmission for my SUBARU Alcyone SVX 1994, do you know where i could find one in Europe ?
Thanks. Pierre-Olivier. |
