Old 09-03-2011, 06:48 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
Re: knocking noise from the engine bottom
Originally Posted by Sean486 View Post
The Coolant Temp Sensor can cause hard starts. It is very easy to replace and only costs about $25.
i know
just bought one online
What is that orange plug , looks empty, for. and is the arrow pointing at the end were you push the wire in or the other end . I don't see the notch
it is empty...don't know what i does tho
the arrow is pointing to the blue wire...you take it out, hold the black connector notch up(its down in the pic) then you stick the wire in the second one from the left, top row
then you put the ignition on "on" and it starts blinking!
took a video, maybe i'll upload it to youtube
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 09-03-2011, 06:59 PM
If you turn the plug so you're looking straight at it, then you'll see.
Old 09-04-2011, 10:53 AM
The NEWBIE
so for the EGR valve, do i need to clean it or replace?
it's under the big aluminum intake thing, right?
DIY FTW!
Old 09-04-2011, 11:08 AM
The EGR I wouldn't worry about unless the code is persistent. That code could be left over from months ago. Clear the codes and see if it comes back. The way to clear the codes in the how-to guide I have never found to work. Unplugging the battery for ~10 minutes works really well though. Then drive the car around and check the codes again and see if it's still there.
Old 09-04-2011, 11:31 AM
The NEWBIE
okay
so all the problems solved
you guys are just the best
DIY FTW!
