Old 10-19-2011, 10:54 AM
Re: EGR valve
RATS 4 more tests . Every 2 years right . So i am due in 13 and then again in 15
Old 10-20-2011, 06:11 AM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Re: EGR valve
Texas does emissions testing? I didn't know that.
What year is your car?
Also, there are two possible EGR codes on the OBD 1 cars, the EGR solenoid and the EGR temp sensor. The 92s didn't have the temp sensor and won't care that it's not there, but the 94s will throw a code if it's missing/unplugged only (regardless of what it reads). They'll all throw a code for the solenoid if it's bad/unplugged.
I have given this some thought and I don't think you're right about the 92's. I saw this because I had a friend, Amy from San Antonio, who had a 92 pearl SVX a few years back and she constantly had issues with the check engine light coming on because of the EGR code. She ended up having the EGR replaced 3 times before she eventually sold it.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 10-20-2011, 10:07 AM
halistan's Avatar
Grand Poo-Bah
Re: EGR valve
On a side note, do we have a "How to" for replacing the EGR? From the diagrams I see of it, if i could find it, I could probably replace it myself rather than taking it to the mechanic.
Anyone have any ideas?
Old 10-20-2011, 11:07 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Re: EGR valve
Originally Posted by 92 SVX View Post
From my reading here and other places the 92 ecu does not look for egr, but 93 and up all do so if you can get a 92 ecu you wont need to worry about it.
I am with icing on this delete the egr and be happy.
how is that possible when i have a 92 throwing an EGR code?
i wish i could just get rid of it.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 10-20-2011, 12:39 PM
Re: EGR valve
Read my post up above.
Old 10-20-2011, 01:00 PM
halistan's Avatar
Grand Poo-Bah
Re: EGR valve
I think he did read it. I believe he is alluding that you are wrong in your assertion that the 92's ECU do not read the EGR codes
Old 10-20-2011, 01:19 PM
B 4 You's Avatar
#lolsvx
Re: EGR valve
i did read it, and i wasn't calling anyone wrong, i'm just wondering what the real answer is, because i own a 1992 (manufactured 09/1991) and it's throwing an EGR code. it might not have the same design or sensors as the later ones, but it has to have one if it's throwing a code..
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-20-2011, 02:21 PM
Re: EGR valve
Ah, I gotcha. Which code number does it give? The list of codes has 3 that I found for the EGR:
34 EGR Solenoid or Circuit
55 EGR Temperature Sensor or Circuit
56 EGR System
I believe that the 92s can only throw the 34. They don't have a temp sensor, like the 94s, and I think only the CA-spec OBD1 cars would throw the 56. That is my understanding at least, from what I've gleaned from the forum.
Old 10-20-2011, 03:49 PM
B 4 You's Avatar
#lolsvx
Re: EGR valve
56 EGR System
that must be which code mine is throwing. i don't remember for certain, but i believe it was 34. and as far s my understanding goes, there's no cheap or easy way to fix it. booo.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-20-2011, 04:08 PM
Re: EGR valve
The solenoid is located at #11 in this diagram. Not the easiest thing to get to, but far from the worst.
But I bet that you could get rid of that code by spraying your cleaner of choice through it, it might just be stuck. Replacing it would definitely work. That's the only electrical part of the the whole EGR system on the 92s, so that's the only way the ECU could know there's anything wrong with it to throw the code.
My plan for deleting it is to use a 92 ECU and leave the solenoid connected and cap off or loop the two nipples on it. Then remove everything else and block it off. The rest of it just connects to the two very small nipples on the top of the throttle bodies, the part that connects to the intake on the back passenger side, and the part that connects to the exhaust on the passenger side exhaust manifold. AFAIK, as long as the solenoid is plugged in and not stuck, it should work fine.
Old 10-20-2011, 07:14 PM
gbianchi gbianchi is offline
Re: EGR valve
Well I'll be watching this for the fix, as I get the CE for egr after a drive and then restarting, unless I pop the hood and let the heat out of the area of the egr solinoid, then no CE, I like the idea of a fix that gets rid of it, my legacys don't have them so I don't need them on the SVX's, Cheers to all....G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 10-20-2011, 09:21 PM
B 4 You's Avatar
#lolsvx
Re: EGR valve
well if there's no risks in spraying cleaner down there, i'll try it. what kind do you suggest? i was going to buy one, but every bottle i saw said, "don't spray on electrical parts or things that get hot." it's an engine...
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 09-30-2012, 07:03 AM
B 4 You's Avatar
#lolsvx
Re: EGR valve
Bumping this because I now have a bottle of seafoam. My buddy said he had an EGR code on an old car, put seafoam in the gas, and never saw the code again. Would I put it through the gas? Vacuum lines? Elsewhere?
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 09-30-2012, 02:25 PM
Re: EGR valve
Far as seafoam goes, I have this image in my SVX folder, I take no responsibility for this:
I don't know who made this pic, or when, or if it is even right, but I did save it to my HDD at some point in the past.
I would also like to say that I also have a 92 (1991 build date), and that I have an ECUtune 1.5 chip installed, and yet I still throw both codes 34 and 56...
Old 09-30-2012, 07:24 PM
92 SVX 92 SVX is offline
Re: EGR valve
California car though other states did not/do not have carb requirements
