Old 11-04-2007, 04:01 PM
Originally Posted by Hondasucks View Post
Just FYI, the Forester S, has a rear LSD, but I don't know the ratio.
So I need to be checking out the diff on my Forester S, 5-Speed....any chance it got the 4.44 5-speed.....I need to check up on this
Old 11-04-2007, 05:42 PM
I believe the new foresters have the 4.44 5mt's... at least thats what I have been told
Old 11-05-2007, 01:16 PM
AlcyoneDaze's Avatar
AlcyoneDaze AlcyoneDaze is offline
<-- custom hood ornament
Send a message via AIM to AlcyoneDaze Send a message via Yahoo to AlcyoneDaze
So... long story short : do I most likely have a 4.11 auto trans on my hands, or a 4.44 - i wanna know before i install the wrong rear diff... just any educated guess would be fine
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L
Donating Forum Member In Good Standing
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 11-05-2007, 01:36 PM
I bought one of those for itsjusteric's car. I told you its probably a 4.11 but unless you pop the front diff off (all those 14mm hex heads around where the bell housing meets the oil pump.) You cannot be sure
Old 11-05-2007, 01:41 PM
okay, FINAL question, I promise, then I'll go away:
I'm just going to go ahead and find a 4.11 diff - specifially a 95 impreza or most auto outbacks/leggacies should be fine to source from, yes?
Old 11-05-2007, 01:44 PM
auto legacies and most mt's have 4.11 rears in em. See if Hocrest has one already
Old 11-05-2007, 01:46 PM
eh, theres a salvage yard with tons of subies in it, they're local and have always treated me right. i'm going to double check my new trans to count the gear teeth (how many = 4.11?) and do the same with the diff, just so i dont have to do this all over
Old 11-05-2007, 03:09 PM
Can you post the trans #s so we can tell you?
Old 11-05-2007, 03:54 PM
will do when i get home...
its TZ102somethinAAA
Old 11-05-2007, 04:03 PM
Please check out this thead.
http://www.subaru-svx.net/forum/show...ght=TZ102Z2CBA
Old 11-05-2007, 08:49 PM
Tz102z1aaa-cc
Old 11-05-2007, 09:37 PM
It's Just Eric's Avatar
Missing in action
Hey,
Just a heads up...you might have some wiring to do. I bought my 4.11 from the same place, and some of the harness was cut Other than that, I cant complain...it was a very, very new tranny with a 3 month warranty.
While you have the car apart, you will probably want to look into filling the trans mount with polyurethane. You'll also want svxfiles to make you his special 4.11 trans resistor to firm the shifts up and prolong the life of the trans
R.I.P Cool Signature.
Old 11-05-2007, 09:55 PM
Yeah thats a 4.11 like what Eric got. I highly suggest doing 1 thing above all else. That is buying the shift resistor from svxfiles. It is a shift kit (kinda) which will prolong the life of that 4.11. I also suggest a fairly large trans cooler if you don't already have one in series with the factory rad cooler (there is a reason its in the radiator). Now if you have a problem finding a 4.11 5 bolt sideplate rear, I just found one in my shop tonight (looking for my 4.44 I found a 4.11 too) Anyway, if you need one in a hurry I can get it to ya
Old 11-06-2007, 08:17 AM
Hey thanks for all the help. There were five trannys there and I picked the one with the least rust, a new oil pan, and all wires and connectors intact; even took an extra dipstick just in case.
Tom, if you want to send me that 4.11 rear that'd be excellent. just let me know how much you want for it and I'll send you a money order ASAP - PM for address and such - time is of the essence
Old 11-06-2007, 12:33 PM
Probably be better if you picked it up. Philly isn't that far
