Old 06-29-2011, 05:35 PM
Blue94 Blue94 is offline
3rd Oxygen Sensor fails after 10k
So I have replaced the left side/driver side O2 sensor 3 times in 10K miles. Each time it lasts for several months to a year ( don't drive it that much ) then the CEL light will come on and I pull a #37. I am wondering if something is causing it to fail i.e. a fault Cat maybe? Any way to test the sensor?
Thanks, Dust
Old 06-29-2011, 08:05 PM
kwren's Avatar
kwren kwren is offline
Re: 3rd Oxygen Sensor fails after 10k
Thanks, Dust
code 37 does not necessarily mean the o2 sensor itself is bad. Ever. Seriously...
Keith
Old 06-29-2011, 08:38 PM
Huskymaniac's Avatar
Uses the ignore feature
Consider the following possibilities:
Check for exhaust leaks
Check for wiring problems (shorted, frayed wires)
Check for inlet air leaks
Check the MAF sensor for proper operation
What brand are you using for the replacement?
Tony
Old 06-29-2011, 08:56 PM
Our O2 sensors are before the cats, so they don't really factor in. It could be that the O2 sensor on that side is getting fouled up somehow. Maybe running too rich or burning oil?
Old 06-29-2011, 11:53 PM
Hmm? well I have the usual leaks, the connection is fairly covered in oil, short of that the car is running fine. No notice of burning oil?
The first two were Bosch then I read on here that many were having problems with them so this last time I ordered an off brand.
Thanks for the ideas guys, I'll have to take a closer look around tomorrow.
Dust
Old 08-14-2011, 03:15 PM
Well I think I fixed it. I wanted to finish this thread so that it will be here for those with similar problems. I search quite a bit here and find it helpful to read about a resolution.
Upon closer inspection I found a broken vacuum hose on the passenger side going into the intake manifold. Right in front of me. Anyway I cut it down and tied it on with a zip tie and walla, runs great and no check engine light. So now I am going to go buy some new hose and do it right. I’m trying to talk myself into pulling the intake manifold and doing them all but I'd be lying if I said just reading about it scares me.
Dust
