tranny problem/no tcu code
i'm afraid my transmission is on its way out shifting into and out of second gear is happening WAY too late, and it feels like the clutch is working WAY too hard in that vicinity. no flare, just a late shift. i'm not getting anything from the TCU except the old code from when i unplugged the resistor to see if that helped (as expected, the shift firmed up, but it still came late - somewhere around 3500-4000 rpm under tame city acceleration). My ATF level is fine and the fluid is clean, but the diff fluid is thick, opaque brown and sludgy. (This could be how it's supposed to be, never dealt with diff fluid before, but i doubt it) I'll be draining and changing that later today.
It seems like 2nd is usually one of the first gears to go when our trannies are dying so am I likely looking at a rebuild? My mechanic reccomended a tranny guy - I'm gonna take it by his shop hopefully tomorrow and he's gonna look it over, but if there's a miracle cure for this (riiiiiiiight ), someone please tell me lol
Kevin Crutchfield Neophyte SVXer 92 LS-L Ebony/Lqd. Silver, stock, 88xxx miles, flung into a telephone pole by a drunk a month after buying 92 LS-L midnight black 141xxx miles, WRX FPR, MAF bypass, lightened underdrive pulley, formerly AppstateSVX's |
The first thing you should do is adjust your T.P.S.(throttle position sensor) to 0.50 volts with the key on, and everything else off.
If the trans is shifting at a higher speed than it should, it is because either, the TCU is seeing the throttle being open wider, than it is. Or it is seeing the road speed as being slower, than it is. If it was seeing a slower signal from the speed sensor, it would be trying to lock up the Transfer clutch. If it saw both speed sensors as slow, the speedo would read slow also. The Throttle Position sensor would be giving a higher than normal, voltage reading, as Tom says. Harvey.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 07-20-2006 at 07:07 PM. |
Diff gear oil is yellow and thick when new; change yours now. Adjust your bands as well (do a search for band adjustment).
Cars I've worked on: '05 Subaru Impreza STi, '02 Subaru Impreza WRX Wagon, '01 Toyota Celica GT, '98 Subaru Legacy GT 2.5 Sedan, '96 Isuzu Rodeo, '95 Jeep Cherokee 2WD, '94 Plymouth Sundance, '94 Subaru SVX LSi, '93 Subaru Impreza, '92 Subaru SVX LS-L, 2003 Subaru Baja. |
Hi, I've got a 92 that is doing the same thing, but also will hunt up and down at steady speed and now sometimes it will start in third gear even if the manual button is pushed and stick is in low. fluid looks good and when acting normal - shifts nice. any suggestions ???? thanks
Starting in 3rd is indication of a malfunctioning (or missing) TCU.
Hunting at a steady speed is usually a bad/dirty signal from the TPS (Throttle Position Sensor)
