Old 08-16-2014, 11:17 AM
jonnyz jonnyz is offline
92 Keeps Dying
I have a 92 svx. 2 weeks ago it started dying when I'm driving. I throw it in neutral, it starts right back up. It seems electrical to me because it starts right back up. I only use super and I did put some heet in it last week. The only thing I know is bad, is one of the 02 sensors. Any Ideas?
Old 08-16-2014, 03:28 PM
Re: 92 Keeps Dying
MAF.
If you check your codes it most likely be a Q23, bad Mass Air Flow sensor.
If you don't know how to check codes go to the members list, look up earthworm, go to his website and it will tell you.
Old 08-16-2014, 05:26 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: 92 Keeps Dying
Ditto, exactly what happened to me and that was what it was.
Gene and Ben
Old 08-16-2014, 07:19 PM
Re: 92 Keeps Dying
MAF for sale here.
http://www.subaru-svx.net/forum/show...&highlight=maf
Old 08-16-2014, 07:29 PM
Re: 92 Keeps Dying
The contacts inside can be re-soldered quite easily. I fixed one of mine that way. There's a "How to" on here somewhere.
Old 08-18-2014, 12:22 PM
Re: 92 Keeps Dying
if you unplug it when the car is off it will run without it. pretty easy way to see if that is the problem and limp it around until you get a new one.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 08-26-2014, 10:45 AM
Unhappy Re: 92 Keeps Dying
Tried unplugging MAF. Started it and it ran for about 10 seconds then died. 3 times.
Old 08-26-2014, 10:57 AM
Re: 92 Keeps Dying
Check all of the vacuum lines at the snorkus.
Two 1/2" lines on the drivers side, a big 1" from the drivers side attaching to the back on the passenger side,
a 1/2" line on the passenger side coming in from the passenger side valve cover,
a 1/2" PCV line coming straight up on the passenger side,
and a 1/2" J shaped line on the passenger side.
Old 08-26-2014, 11:56 AM
Re: 92 Keeps Dying
was the key off when you unplugged it? can you keep it running by holding down the gas?
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 08-26-2014, 12:59 PM
Re: 92 Keeps Dying
Yes, the key was off. I just tried it again, and if I keep my foot in it about 1200 rpm it will run. I took my foot off the gas and it slowly died.
Old 08-26-2014, 01:02 PM
Re: 92 Keeps Dying
will check vac lines later. gotta work.
Old 09-03-2014, 03:22 PM
Re: 92 Keeps Dying
First off, thanks for all the help. I was ready to resolder the maf, before I did that I sprayed it (the heat wire) with brake cleaner, Problem solved. Also when I was checking the vac lines, for some reason the guy I bought it from had put 2 fuel filters on the cruise control vac line. Not sure what his thinking was on that, I cut those out and hey! my cruise control works!
Old 09-03-2014, 04:05 PM
Re: 92 Keeps Dying
Gotta love that. 2 birds with one stone and no money involved.
Old 09-03-2014, 04:08 PM
Re: 92 Keeps Dying
And the cruise control has its own electric vacuum pump!
