Old 05-26-2013, 12:24 PM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Re: Got some money, want some power+stick
Originally Posted by Tapani View Post
Isn't it time someone built an electric SVX?
Separate motors running front / rear ends? Modern AC technology...
http://www.diyelectriccar.com/forums/
/Tapanu
I want to build an electric SVX
Not sure if 2 or 4 axle mounted motors would do it. I always imagined two larger flat packed affairs in the middle (floor) with power transfered via differentials. AWD is implemented by setting the power distribution manually to each motor or let a sensor fed cpu control the flow. Possibly the diffs could be electronically adjustable to allow for individual wheel control. Battery packs by the firewall and where the fuel tank used to be.
User purpose AWD and low center of gravity, middie balace.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 05-26-2013, 12:44 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
Originally Posted by Sean486 View Post
I have to say I'd be surprised if this project gets anywhere.
Me too. But if it works out it'll be awesome. Wish me good luck!
/Tapanu
Too expensive...In one of the posts they are saying 8k just in batteries, for a 35mile range! That's insane!
Not sure if 2 or 4 axle mounted motors would do it. I always imagined two larger flat packed affairs in the middle (floor) with power transfered via differentials. AWD is implemented by setting the power distribution manually to each motor or let a sensor based cpu control the flow. Possibly the diffs could be electronically adjustable to allow for individual wheel AWD. Battery packs by the firewall and where the fuel tank used to be.
User purpose AWD and low center of gravity.
please do it!
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 05-26-2013, 06:15 PM
Good Luck man!
Old 05-26-2013, 09:36 PM
I have to see if I have a friend who can stuff a V8 in the place of an EG33 (icingdeath approves? )
Do what makes you happy, man. But talk to the guy who was doing the SBC swap before you do anything, and see why he ditched the V8 for a Nissan twin turbo V6. Having spent quite a bit of time on the msextra forums, and gained a great appreciation for LSx motors.
Old 05-26-2013, 11:57 PM
The NEWBIE
I meant the EG33
But yeah, I asked him and his problem with the LT was lack of power and bad trans. His was carbed. Mine will definitely be injected, so that solves the power issue, and I take tons of low/mid range over a better trans! He also said that the LT was an easier fit, which is odd but I'd better take his word for it!
So after quite a bit of discussion about the LS1 and such, I am convinced that a full Vette swap is just too much work. So I'll probably go for a Camaro swap.
Two questions for you guys:
1. What is the outer size of the 4eat? How much extra room will I have for the T56?
2. Are the mounting points for the EG33 the same or similar to the flat 4's? Can I buy a conversion kit(F4 to LS) and use it successfully?
DIY FTW!
Old 05-27-2013, 01:34 AM
The mounting points are similar to those of an impreza, but not the same. You'd have to try it and see how well anything fits. The main differences between the engine bays of the SVX and newer imprezas is there is more space lengthwise, because the EG33 is longer than the flat-4s, and there is less vertical height, due to the lower hoodline. An LSx might be a little too tall, and you might have to make a hood bulge or scoop or something.
Old 05-27-2013, 02:21 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
...see why he ditched the V8 for a Nissan twin turbo V6.
The VG30DETT is awful to work on. 40+ vacuum lines and literally almost no room to work on it in the engine bay. Also all the plastic used on that engine is susceptible to heat and breaks easy.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 05-27-2013, 02:36 AM
The NEWBIE
Yeah, especially if I decide to supercharge! But honestly that's one of the smallest problems! There is a reason why few people have tried this!
Yeah but he says he'll be pushing 500hp! Very decent power
DIY FTW!
Old 05-27-2013, 10:58 AM
He's also going large single turbo... It will be extremely far from a stock engine.
Old 05-27-2013, 01:12 PM
Tapani Tapani is offline
Get an EZ36 from a Tribeca and a Rotrex centrifugal.
This one was built over here:
http://legacygt.com/forums/showthrea...-0r-68613.html
Or just do it with the EG33 and save a ton of hassle on engine management.
/T
Old 05-27-2013, 05:55 PM
There is a guy on here / Facebook selling his Turbo SVX 5 speed, just needs work on the Transmission.
http://www.subaru-svx.net/forum/showthread.php?t=61750
Old 05-27-2013, 11:32 PM
The NEWBIE
and shipment from IL to CA!
BTW, he says he has 6k into the car! Turbo SVX + WRX 5sp for 6k?! Anybody wanna go tell him that it's impossibaru?!
Nobody answered my question about the size of the 4eat...I kinda need the info, so please? Pretty please?
DIY FTW!
Old 05-28-2013, 04:34 AM
The car was built by PhastSVX, not the current owner. Plenty of history on here about the build.
