Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #361
Old 02-10-2008, 03:03 PM
longassname's Avatar
Just some dude.
nermind........so anyway..thanks chuck..I wouldn't say I am up and running but my eye seems good and the swelling in my knee is going down..I should have surgery before too long
Old 02-10-2008, 03:39 PM
Originally Posted by longassname View Post
The idle must also be raised to the neighborhood of 800 rpms. I will release matching engine management software with an adjusted idle and transmission control unit software with high rpm shift points shortly.
Have you tried raising the idle speed by simply resetting the set point on the BPACSV rotary solenoid?
To save typing I have extracted text from my earlier write up.
The By-Pass Air Control Solenoid Valve, or Idle Air Control Valve, allows the Engine Control Unit, to control an adjustable inlet of air in order to control idle speed when the throttles are shut. One obvious function is to increase the airflow when the air conditioning system imposes an extra load on the engine. The SVX has a second valve, The Bypass Air Control Valve, to supply extra air during cold starting.
The unit comprises a rotary solenoid valve, biased towards a central rest position by means of a permanent magnet. A double wound coil provides reversing open closed operation from a mean rest position, at which point the valve is half open. (Presumably the normal static idle position.) This arrangement provides two way variable control, dependent on the applied voltage.
Adjustment of the mean position is provide for by incorporating slotted screw holes in the housing, probably to allow the position to be set during manufacture in order to allow for anticipated tolerances.
N.B. Edit ---- Having had second thoughts, there are reasons why this will not work, because the ECU will always try to adjust the AACSV in accordance with the idle speed fixed by the software. But what if the valve is modified/adjusted so that it can not completely shut off air to the point where the engine stalls? I seem to recall that an a mechanically adjustable auxiliary overriding air bypass was discussed at one point, I understand with some success.
What would occur if the closing signal is inhibited by means of a resistor or completely disconnected, then the minimum idle set by adjusting the ACASV? The opening signal should continue to operate to adjust for extraneous loads and there would be a fixed low idle, but the ECU would have no control over the minimum idle. Admittedly this could maintained as accurately.
If the connecting tubes were temporally extended, experiments could easily be carried out and be worthwhile.
Old 02-10-2008, 06:49 PM
KristinsSVX KristinsSVX is offline
Banned
Post
These are the Dyno results from enhancedstreetperformance.com. They said they stopped at peak power.
Old 02-10-2008, 07:06 PM
Just some dude.
here are the plots i was sent of that dyno session
http://www.ecutune.com/posts/svxhp[1].pdf
Old 02-10-2008, 07:22 PM
Just some dude.
And here is somebody's stock svx plot for comparison..I don't know who's.
http://www.ecutune.com/posts/stocksvx.jpg
Old 02-10-2008, 07:32 PM
Wow, HP is an awesome line. Almost perfectly linear from 2700-6000 RPM.
Old 02-10-2008, 07:43 PM
Banned
Why does the Stock motor say 176 max power, but the graph points to 149?
Old 02-10-2008, 09:37 PM
Just some dude.
149 is obviously the correct number...no idea what bug made the sumary grab that 176# but the plots are good. I believe that is one of the dyno plots from the guy who used to test out different exhaust set ups and dyno them. There are other stock/stockish svx plots around and they all show the same thing--torque peaks at 4400 rpms and drops like a rock, from 4400 rpms the slope of power curve continually decreases until it peaks at 5600 rpms and inverts to a steady decrease. I grabbed this one because I found it first.
Old 02-10-2008, 10:42 PM
Banned
Do you think enhancedstreetperformance.com was wrong on the peak power, that it could still climb to the 7,400 redline?
Old 02-11-2008, 04:51 PM
Just some dude.
It's clear in the plots that torque hasn't even peaked at the just over 6k rpms they took it to.
Old 02-11-2008, 04:53 PM
Just some dude.
i see there is a sticky version of this cam thread but it is actually apearing as a copy..should I just stop posting in this one and go to that one?
