Old 12-21-2006, 02:06 PM
lol, I was about to say something like that. When does the snow clear out in Alaska?
Old 12-21-2006, 02:49 PM
April-ish.
Old 12-24-2006, 07:52 PM
Mission Mission is offline
Originally Posted by shotgunslade
I have a custom mandrel bent stainless steel exhaust system that is similar in configuration to the stock system. It was fabricated by Mufflex in Hamilton, NJ. The tips are from Dayle. My main muffler is a Bullet. Single 2 1/2" inlet, dual 2 1/4" outlets. I finally found their website:
http://www.bulletperformance.com/um_dual_9c.htm
Here's a picture:
If you dont mind answering this question. How much did your setup cost?
Old 12-24-2006, 07:59 PM
Shweet exhaust Nik.
Old 12-25-2006, 08:14 PM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
Still loving my cat-back Stebro. Nice clean rumble at idle, great tone maintaining speed, fuhq'ing impressive on rapid acceleration.
When I had the old system off, before putting the new one in, I started and revved up the engine with nothing but the cat-forward....Niiiiice roar!
Dave W.
______________________________
1996 Redd
Old 12-26-2006, 08:58 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
I think it was about $800 installed, including main cat, resonator and muffler.
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 12-26-2006, 02:59 PM
GreenMarine's Avatar
GreenMarine GreenMarine is offline
From POST-***** to LURKER
3 Piece Stebro with Metallic sub-strate Pre-CAT's .... THAT is music ladies and gentlemen... Hell, I have had a blown speaker in my car that I couldn't bother to get fixed because the exhaust is music enough
2020 Subaru Outback Touring - Wife's first Subaru
2005 Volvo V70R - 5-cylinder love! :Heart:
** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned
** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!!
** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love...
Old 12-27-2006, 04:21 AM
Thanks. Its a better price than I thought.
Old 01-11-2007, 07:37 PM
Yoda3000's Avatar
Yoda3000 Yoda3000 is offline
(This account is in rememberance of)Duct Tape Man
Send a message via AIM to Yoda3000
So do most of these systems have much performance gain?
Specifically shotgunslade's?
Also, which peice gets the most performance gain the 2-1 main cat?
Early deceased SVXWN Member
July 1986 -- February 2007
Michael - Duct Tape Man
1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit
1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something.
"It's only after we've lost everything that we're free to do anything" - Fight Club
"This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X
