stock battery vs. Red top??
I wanted to know the if there was an exceptional difference in the red top that would justify spending double the money for one? If you have used a redtop currently of previously your imput would be aprreicated. I just can't see spending $150.00 on one so make my decision easier with some opinions.
thanks guys Mike
looking for svx former owner- 94-L 124,000(traded it when tranny went bad) |
I've had a red and yellow and they made absolutely no difference at all. Sometimes I tried making myself believe the fan blew harder or the car started up quicker, but they didn't. Go buy your girlfriend a nice dinner or something.
Brian |
The reason I bought mine was so that I could mount it in the trunk to make room under the hood for my supercharger.
It does not require ventilation, so there is very little chance of explosion.
Optima batteries are in a class of batteries called "sealed lead acid (SLA) batteries". They are sealed (actually nearly sealed) and require no maintenance. The Optima Red Top model 25 is the battery that Optima recommends for the SVX. Its about 10 lbs less than a standard battery for the SVX. These types of batteries typically provide good engine cranking power for their size. There is a penalty for the lighter weight though... They have a lower reserve capacity than a heavier battery. This particular Optima battery probably has a reserve capacity of around 60 minutes while a standard battery for the SVX would have a reserve capacity of 90-120 minutes. Optima batteries seemed to be way over-priced. The same technology is available in other brands of batteries that sell for less (Hawker Odyssey for example). Several people on the board have had their Optima battery go permanently dead after a relatively short period of time (less than 3 yrs). This may be due to the alternator voltage. SLA batteries are more finicky about the alternator charging voltage than standard car batteries.
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 01-19-2006 at 10:23 AM. |
My yellow top died in 10 months
Brian |
HENRY 92 SVX Claret(No More) 12 Camaro ZL1 89 Yamaha FJ1200 07 Yamaha FJR1300 "GO RAVENS" |
I see normal cars with normal batteries driving around in very cold weather without issues.. It's too bad you can't do core exchanges with your old battery when buying an optima or it may be worth it.
Brian |
I have had optima red tops in both of my SVX's, exceeding 3 years each, without any problems whatsoever.
I used the Optima battery red34-top terminal only Optima #8002-0020 (34-980) This battery is rated at 800CCA (BCI 0°F) and has a reserve capacity BCI:110 minutes. It works really well if you have done the alternator wiring upgrade. I like the fact that I can use it without the battery box (just a battery mat underneath). Gives me a lot more room. Photo with aluminum-coated stock hold down bracket and knurled chrome knobs from a Lamborghini. Advance Auto Part no. 16080022...$118.88 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 01-19-2006 at 10:35 AM. |
I've been driving for over 30 years and have always gotten about four years' reliable service out of the cheapest no-name battery on the shelf, which is about the same anyone would expect from a top-dollar brand.
For the SVX, I splurged and went for a mid-priced no-name. dcb |
I got a 990 CCA battery from sears for around $90. Over two years with my stereo and it still works great.
thanks guy's I think I am going to go with the " you get what you pay for" theory.
thanks Mike
Brian |
It's the infamous alternator wiring mod. It's all over the place.
Here is the thread: http://www.subaru-svx.net/forum/show...r+test+results It doesn't take long to do. In fact I did three of them in a row at the Lafayette meet, starting around 1:30am. (I am in the middle, the tired-looking guy staring at the camera is Zeppelin) There are also photos in the How-to locker here: http://www.subaru-svx.net/photos/files/How-To/27325.pdf .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 01-19-2006 at 02:35 PM. |
Great thank you very much
Brian |
