Old 07-18-2010, 06:38 PM
willisjefferyl willisjefferyl is offline
Banned
Knock Sensors
I just checked my engine codes and got a 22 and 28. I was wondering what bad knock sensors will do? If anyone has any? and how complicated they are to put replace? Thanks
Old 07-18-2010, 07:53 PM
Re: Knock Sensors
If you need to change out either of your knock sensors it is best if you remove the alternator, (after removing the -terminal from the battery)
to give better access.
If you need to replace the #1 knock sensor on the passenger side it is also helpful to remove the power steering pump.
http://www.subaru-svx.net/photos/use...svxfiles|23592
Old 07-18-2010, 07:54 PM
immortal_suby's Avatar
Thread Killah
Re: Knock Sensors
They are pretty simple to replace if you have the hands of a 5 year old, just one bolt and a plug and they are out. Unfortunately they are buried under the intake manifold and are a little tough to get to with normal sized hands and tools. It can be done without removing the manifold, it just takes time and patience.
Here is where they are located
Locker Link
2015 BRZ Limited 6MT
Old 07-18-2010, 07:56 PM
Re: Knock Sensors
Matt, My engine does not have those cool red rings?!?!
Old 07-18-2010, 07:59 PM
Thread Killah
Re: Knock Sensors
They're good for 20hp and 0.8 sec in the 1/4
Locker Link
Old 07-18-2010, 08:10 PM
Re: Knock Sensors
Can I haz some cool red circle thingies?
