#121
svx transmissions
any body remember this article?
http://autospeed.com.au/cms/A_1831/a...popularArticle It mentions using the liberty rs tranny as a possible replacement. Ever been done before? I think it made reference to a wrx auto tranny? Did the wrx ever use an auto transmission? |
#122
Also the trany resistors from Legacy/outbacks are direct plug and play. But the part numbers are different.
MAF from some nissan/infiniti will work as well.
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD 92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD 92 Teal SVX LSL lowered with Konig. SOLD 92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone 94 Red SVX L FWDwith LSL Leather Interior. SOLD 92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD 95 Polo Green........With Trany Problem. GONE Almost complete Rear Wheel Bearings Job with Pictures in my locker My Locker http://www.subaru-svx.net/photos/user.php?pearlm30 |
#123
Re: What parts are compatible between SVX and other cars?
I am going to resurrect this to potentially add one item. I believe a K&N HP-4001 oil filter should fit. Can anyone confirm? It is an alternative to the Purolator 30165.
Also, I believe the Mobil 1 M1-401 used to fit before they discontinued it. Too bad because this would have been a bigger and higher efficiency filter. The K&N is a little more efficient that the standard Purolator but neither is anywhere as good as a Mobil 1 or Purolator Pure One filter. So we can either get a standard size but high efficiency or we can get a larger but not high efficiency.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 09-13-2010 at 06:50 AM. |
#124
I'm running a tranny resistor I pulled off a '93 Infiniti G20 (made by Nissan). It's made by JECS and plugs in directly, but I'm sure the part number is different. I'm sure my knock sensor came off a Legacy or Impreza too.
#125
BUMP this needs up dating . How a bout the EGR valve I was told any Legacy fits
#126
I second the idea of updating this thread. Also does anyone know what year/model Nissan/Infinity MAF will swap and does this include the MAF sensor?
#127
However, there appears to be yet another alternative for a "large" or "oversized" filter. It is the Bosch 72158 Premium Oil Filter. According to this test: http://filtrationcomparisons.weebly....d-results.html the Bosch is basically identical to the Purolator PureOne. So now we have a super efficient oversized filter option AND it is less expensive than the K&N! One drawback is that it doesn't flow as well as the K&N BUT the newer P1 filters in the gold cans flow MUCH better than the old blue can versions so flow is not really a concern and should be no problem given that this is an oversized filter to start with. According to this guy's conclusions: http://filtrationcomparisons.weebly....nclusions.html the build quality of the Bosch/P1 filters are not quite as good as the K&N so that is another possible drawback. But I have also read that the check valves in the M1 and K&N filters slowly leak and that can be a concern for some engines in terms of dry starts. I'm not sure if that applies to the SVX. As far as overall build quality is concerned, this guy: http://www.gmtruckcentral.com/articl...gradesheet.htm agrees that the P1 is not quite as good as the K&N but "B+" is still a pretty darn good rating. At some point, good is good enough. The K&N may be bullet proof but I doubt anyone will experience a Bosch/P1 filter self destruct. Given our tight bearing tolerances, I think filtration is most important. Given our high engine temperatures, the higher flow of an oversized filter is also a big benefit since it will keep oil flowing and help distribute heat more evenly. A second benefit of these larger filters is that they will stay out of bypass to higher RPMs and will maintain good flow rate over a longer period of time. Both mean that there is less chance the engine will see unfiltered oil due to bypass. I suppose the Bosch/P1 and K&N filter choice (both oversized) could be a coin flip with lower cost pushing the P1/Bosch to the top.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 07-21-2011 at 09:37 PM. |
#128
Can we resurrect this thread and update it with new info? I need to replace my alternator and wonder if there is a higher output alternator that we fit our SVX?
#129
All other Subaru alternators are slightly different. Your best bet is to get a rebuild either through a good local shop or from Maniac http://www.subaru-svx.net/forum/showthread.php?t=49821
I have their standard and it is great. They also make a high output that many folks have gotten.
#130
Thanks. I've been in contact with them.
#131
As a new guy I started reading this thread. After looking through it for a bit I decided to do something useful. http://ootfab.webhop.net/ootfab/tech/crossref_SVX.cfm This link is the output to a database. Items can be added here: http://ootfab.webhop.net/ootfab/tech/addrefSVX.cfm I put the Nissan Altima cooling fans in as an example. I'll continue to read through the thread to extract parts and their numbers. Feel free to add to the cross reference. Of course if someone had a Hollander subscription... -Mike O Last edited by injuhneer; 10-18-2012 at 01:50 PM. |
#132
Nice! That's a decent start. How well-hosted is it? If it lasts a long time, and grows, then it will be extremely useful, but if the hosting (or funding for the hosting) is not reliable, then not so much.
Also (and I mean this in general, not just in the DB you just made). Can we avoid things like "impreza or legacy such and such will fit" and "contemporary Altima" and put in actual years, or even just one year? That will make a big difference to people who know the least about cars in general, and therefore need the most help.
#133
-Mike O |
#134
$188.00 exchange. 1 year warranty..... (Stock units are only 95A on a good day) $248.00 outright FREE ground shipping Lifetime warranty available. $98.00 Talk to Christian .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-18-2012 at 02:41 PM. |
#135
I have done several of the cross references (Citroen SM, Yamaha XJ, Saab 900, etc). All of them are still available to folks even though my projects change. Of course "contemporary" means "in the same era" so an Altima of the same model year or just preceding is implied. But I agree with your point. I am currently looking for suitable suspension bits that cross from other vehicles. The Subaru interchanges are helpful but I am interested also in interchange with other manufacturers. Even if minor modifications are needed it is still worth compiling. Thanks for the input. -Mike O |
