Old 01-09-2013, 05:27 PM
ddmd ddmd is offline
Headlight and turn signal removal
If anyone can help, I'm trying to remove the headlight from my SVX. It looks like I need to remove the turn signal light first, but, so far, I can't figure it out. Thanks in advance.
Old 01-09-2013, 05:37 PM
Re: Headlight and turn signal removal
The turn signals are easy, there is one screw on the top visible with the hood open, after you undo that, they come right. Then you will see the bolts on the side for the headlights. There are bolts on the other side behind the grille as well. In the how-to section I believe there are instructions for removing the grille - follow them closely since the tabs that hold the grille on can be a pain to deal with.
Old 01-09-2013, 06:52 PM
BEHIND GRILLE. 2 bolts
BEHIND TURN SIGNAL. 2 bolts
Old 01-09-2013, 08:01 PM
Wow, you're amazing. Thanks for the fast responses. And great pics. I did have the grille off and removed the bolts and the top screw, but was looking for something else holding the turn light in. The fender is crushed a little just above the turn light so hopefully it will still slide out. I'll try after work in the next couple of days. Thanks again.
Old 01-09-2013, 08:03 PM
Are those pictures with labels from a manual that you have, or did you make them yourself?
Old 01-25-2013, 09:16 AM
Thanks everyone,
After I straightened out the fender tip, the turn signal lamp assy slid right out
Old 01-25-2013, 10:29 AM
I made them myelf. I have posted hundreds over the years to clarify things such as this.
The first photo looks a little odd because I have the clear polycarb headlight shields installed ovr the headlights.
Old 01-25-2013, 12:59 PM
theflystyle's Avatar
awesome how-to. much appreciated.
1994 SVX LSi
2008 Legacy 3.0R
Old 01-27-2013, 12:21 AM
Did you check the How-To Documents? This how to is under Body.
Old 01-27-2013, 08:56 AM
Well thank you because it clarified everything.
Old 01-27-2013, 09:01 AM
Oops, no I didn't. I don't remember what I used to search the forum but it didn't come up. I'm still learning about the forum so I'll check there next time. Thanks
Old 04-16-2013, 07:56 PM
lsupcar lsupcar is offline
Are there more details somewhere on how to remove the center grille?
