Old 10-15-2012, 09:05 PM
tjpops tjpops is offline
Oil Leak Diagnosis help
Hey all - haven't been on the forum for years - good to be back. Our 92 has an oil leak at the front bottom of the engine. It leaks onto the tray just behind the front bumper then drips through the holes. I've attached a couple of pictures though they may be hard to understand. The one is taken to the left of the oil filter. The second is on the same axis but further left along the bottom front of the engine. We're not mechanical and I'm forever suspect of letting someone who doesn't know these cars start to play. Appreciate any help with what our problem might be - thanks.
92 Pearl White
Canadian, eh!
Old 10-15-2012, 10:05 PM
Re: Oil Leak Diagnosis help
What do you mean by the "tray". Do you mean the black plastic cover that is over the timing belt? Oil leaks from that area are usually bad Cam seals.
Old 10-15-2012, 10:20 PM
Looks like the timing covers in the pictures. Cam seals/plugs and crank seal are the only things under there that can leak. Or it could possibly be something leaking from the top through them and all the way down.
Old 10-15-2012, 10:36 PM
By the 'tray' I mean the plastic shroud that you need to remove to access the oil filter. It's under the car immediately behind the front bumper and goes back about a foot the width of the car.
Thanks for your thoughts on this problem!
Are these diagnosis major repairs in terms of parts and cost?
92 Pearl White
Canadian, eh!
Old 10-16-2012, 04:55 AM
For those seals, parts are just few dollars but unfortunately there is a lot of labor because of where they are located. I am guessing 3-4 hours of shop time.
Old 10-16-2012, 01:08 PM
bishop bishop is offline
looks like my engine, found one of my cam seals was about to walk while the other was only leaking a little.
