Wiring diagrams for 96/OBD2
Can someone point me to known accurate wiring diagrams for my 1996 OBD2 car? I found some supposed 1997 service manuals that came from what appears to be a Russian source but some stuff in there about torque values and wheel bearing parts was not accurate so I don't feel I can trust the wiring diagrams either. I am working on some interesting projects involving the TCU and ECU for us poor OBD2 folks.
Re: Wiring diagrams for 96/OBD2
What do u need to know?
Tom |
I want to know all of the wires going to and from both the TCU and ECU and their color codes.
I can try and look that up on my old mitchel disc. Do you mind if i ask the goal of this?
Tom |
1. I have built a little electronic module that can be clamped onto the ATF temp sensor line to read that sensor directly. It converts the voltage to a temperature and displays it on an LED readout. I want to make sure I tap into the correct lines for the sensor, ground and power. 2. I would like to start thinking about how one would program a standalone EMS to interface to my TCU. 3. I would like to see if there is a way to fool the TCU into doing things a little differently like lock up the Torque Converter in third gear when the stick is in "3".
http://www.phantomotaku.com/SVX/
Has some service manuals, with some wiring diagrams. I have also attached some things that may be useful. http://www.subaru-svx.net/photos/fil...ye95/12431.PDF
