Old 04-24-2012, 06:20 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Another wiring question.
So, power mode is successful. I have a nice pushbutton switch tucked away somewhere, but it's bothering me that I don't have a real place for it. I had an idea though, but I didn't do it for fear of breaking something. The parking lights switch. It's in a perfect, discreet location, and wouldn't require adding any holes (my biggest fear). Can I simply connect my power mode switch to the terminals of the parking lights switch? In theory, when the button is pushed, the parking lights and power mode will both come on. Will this have any negative effects on the car? It's probably a stupid question, but I'm afraid connecting the ecu to another input of voltage will confuse or damage it. If I don't, I'll just disconnect the parking lights switch and rewire it to house my power mode switch.
PS, if someone has an image of the switch from the back so I know which terminals are power, which are lights, etc. that would be fantastic!
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 04-24-2012, 06:28 PM
dbarnblatt's Avatar
Re: Another wiring question.
Why not do exactly what you want to do but get another set of switches... on ebay all the time:
http://www.ebay.com/itm/92-97-Subaru...-/140555444225
... and install this new switch on the right side of the steering wheel where the "coin holder" is now. It will fit right in with no modification.
Old 04-24-2012, 06:46 PM
B 4 You's Avatar
#lolsvx
I already have that same new switch where you described, both with switches in use.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 04-24-2012, 06:50 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Can you post some pictures and explain the power mode installation?
The photos on the original thread on this subject was removed. Thanks!
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 04-24-2012, 07:40 PM
B 4 You's Avatar
#lolsvx
I didn't take any pictures, but if you read this and check the photos on page 12, you should be able to do it.
http://www.subaru-svx.net/forum/show...r+mode&page=12
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 04-24-2012, 08:09 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
I don't think the parking light switch would work, because it is switching power to the parking lights (I assume) and the Power mode requires grounding the pin on the TCU. So if you connected the power mode wires to it as well, you would effectively create a dead short to the parking light circuit and give battery power to the pin on the TCU, which I'm guessing would not be cool for it.
If you have access to a parts car, steal the shift lock button from it and mount a little push on/off switch under it to put below the shift lever. I just did this in my car (installed it today actually :-), and it works well. No drilling any holes, and it looks stock. I also am using the coin holder spot for switches, and I've already made a switch next to the rear defroster button, so the spot below the shifter was my only option. Parts cars are handy
I'll be adding some pics to my locker when I get a few spare minutes...
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 04-24-2012, 08:38 PM
B 4 You's Avatar
#lolsvx
Originally Posted by SVX8588 View Post
II've already made a switch next to the rear defroster button
I already made this switch press-able, but I can't figure out how to get a switch in there. How did you do it? I was going to do the manual mode with a shift-lock switch originally, but nobody has one available anywhere and it seemed to be too much of a hassle. I'll probably disconnect the parking lights wires and reconnect the power mode switch wires.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 04-24-2012, 10:19 PM
I used the "manual" button on the shifter when I did it in my black '97. I added a DPST switch that switches it back to do the manual mode thing. (Although there is a loose wire somewhere so the manual mode doesn't actually work, but I don't care, manual mode is useless.) You must keep the manual button able to work somehow in case you need to check codes, since the procedure to check tranny codes requires pressing the manual button. The OBD2 cars don't need this however, since you can also just check trans codes through the code reader.
I really like the manual button on the shifter for power mode, I use it very regularly when I'm using my black SVX (I switch DDs every month or so).
Old 04-24-2012, 11:23 PM
B 4 You's Avatar
#lolsvx
Manual mode is actually very useful to me. My brake band needs an adjustment, because at slow speeds and low RPM's, it get's confused and shifts hard occasionally. If I put it in manual mode during traffic or parking lot speeds, I can decide when to shift (if at all, I usually just leave it in 2nd), making it much easier on my brake band
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 04-24-2012, 11:37 PM
Green1995SVX's Avatar
Manual mode is most certainly not useless. It has a very specific, and very helpful use. It allows you to start from a stop in second gear which is very useful in winter conditions.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-25-2012, 12:31 AM
Da f*** is winter?
Old 04-25-2012, 12:39 AM
STiLtd683's Avatar
STiLtd683 STiLtd683 is offline
Da f*** is winter?
I think it's that short time that you get a respite from the humidity.
'94 SVX
'92 SVX
Old 04-25-2012, 12:41 AM
I....
what?
Old 04-25-2012, 07:27 AM
radarwhiz's Avatar
Fairmont State University
Does this help or give you ideas? This is how I did mine.
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 04-25-2012, 07:58 AM
B 4 You's Avatar
#lolsvx
Mine is exactly the same.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
