Old 12-22-2007, 04:19 PM
robyo23's Avatar
robyo23 robyo23 is offline
New Stereo Deck + MPG Guages?
Over the winter I plan on putting a new head-unit into my SVX. Probably Alpine or similar.
Now with the empty DIN space I was considering mounting a number of guages - transmission temp - engine pressure....and...
I was wondering if there is a way of also mounting a guage that displays the average MPG or MPG you are currently getting.
I know alot of GM cars come with LED or HUD that will display this, and if an LED system can be installed in the bottom that woul dbe nice, But i was thinking more along the lines of BMW - My friend has a 2001 323ci and in the dashboard beside the speedometer there is a little neddle that goes back and forth displaying the MPG of the car.
Basically is it possible to install one of these on our cars? And has anyone done or tried it?
Any other comments appreciated.
Thank ya -
Rob
1992 SVX LS-L Pealie
Audio - Alpine Type X Components with Alpine Type R 3-ways.
Infinity 12" Perfect 4ohm sub in custom shallow box.
ECUtune Stage 1v5
Old 12-22-2007, 05:48 PM
Hondasucks's Avatar
Subaru Technician
I know the XT6 came with a trip computer, but I'm not sure if it would display MPG... And I don't know how you'd go about wiring it into an SVX, if it's even possible.. But if it is possible, that's one route.
Check Summit Racing, they might have a fuel economy gauge...
1986 VW Jetta
Old 12-22-2007, 06:14 PM
Some sort of wideband, cross-referenced with speed....I'm not sure it can be done aftermarket, you'd need a sensor to determine how much fuel is being used, another to monitor speed, and then software to calculate the two to figure out mileage.
Old 12-22-2007, 06:29 PM
robyo23's Avatar
http://www.pureenergysystems.com/store/Scan_Gauge/
is the closest i found. Unfortunantly for OBDII only . That would have been perfect too.. I guess I'll keep looking or give up.
Anybody else try a similar setup as to what I described? Radio + guages underneath or above?
ECUtune Stage 1v5
Old 12-22-2007, 06:38 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
The radio and gauge deally has been done. Some of them have been documented in the forum.
To my knowledge, the instant fuel economy calculators tap right into the ECU and base their number on speed and the injector firings. It's not something you are going to have any easy time implementing on an SVX!
If you're looking for a sloppy alternative, I believe the pre-digital economy estimators were simply sourced from vacuum or narrowband O2 sensors hooked to gauges marked (surprise) lean, rich, and optimal or something. You may as well just ask your foot if it's on the floor.
Old 12-23-2007, 05:39 AM
Manarius's Avatar
Manarius Manarius is offline
Yeah. I remember a guy over on USMB saying how the best MPG indicator is a vacuum gauge. Try to keep it over to the left and you're making the best mpg
-Jason
-Obi Wan Kenobi
Old 12-23-2007, 10:30 AM
AFBeefcake's Avatar
AFBeefcake AFBeefcake is offline
Subaru Swapper
Send a message via AIM to AFBeefcake
I have gauges under my stereo.
http://www.subaru-svx.net/photos/fil...cake/27992.JPG
2005 Legacy GT
2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles
My WRX's Cardomain Page
Old 12-23-2007, 12:08 PM
94SubieSVX's Avatar
94SubieSVX 94SubieSVX is offline
OOC for a while
Send a message via AIM to 94SubieSVX
Originally Posted by AFBeefcake View Post
Doesn't the screen hit the climate control?
bLAh
Old 12-23-2007, 02:23 PM
AFBeefcake's Avatar
Subaru Swapper
At its lowest setting it just clears.
2005 Legacy GT
Old 12-23-2007, 02:32 PM
94SubieSVX's Avatar
OOC for a while
Ouch, that's gotta hurt the neck trying to look and drive
bLAh
Old 12-23-2007, 03:13 PM
AFBeefcake's Avatar
Subaru Swapper
Its not to bad. The dash is angled back. so the screen when open sits right ware you can see it good.
2005 Legacy GT
