Old 03-22-2011, 06:55 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Help identify a part
Looking down in between the alternator and the power steering pump reservoir, there is some type of sensor...mine has a small trace of oil coming from the top of it. What is this sensor and is it easy to remove with a socket?
1995 Subaru Svx L / AWD
Old 03-22-2011, 07:36 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: Help identify a part
Oil pressure sensor and yes it's easy to change with a socket.
Wanted: Steering Wheel
Old 03-22-2011, 08:06 PM
msvx95's Avatar
It's just a phase
ok thank you...I searched and it looks like it's a fairly cheap part at autozone for 10.99
Old 03-22-2011, 08:15 PM
Good.
But may I suggest that you only replace it with a Genuine Subaru
"switch assy, oil pre" # 25240KA040.
And here is why, if you use an aftermarket switch it is more than likely that your oil pressure warning light will be on at idle,
causing you to go
WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!! !!!!!!!!!!!!!!!
and spew milk and vodka all over your dash board!
The socket used should be a 24mm six point.
Last edited by svxfiles; 03-22-2011 at 10:02 PM. Reason: The reason thats in bold is in case Cam comments later!
Old 03-22-2011, 08:19 PM
msvx95's Avatar
It's just a phase
Thanks Tom, I was looking at Advanced auto's sensor and they want 38.99, but it's 100psi...not sure which one to get or what I really need, but I would be safe with the Subaru part number that you have provided. You beat me to asking that question.
Old 03-22-2011, 09:59 PM
Cam Cam is offline
Make sure you use a 6 point socket. A 12 point could round it out. They are pretty soft and are in there TIGHT.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 03-23-2011, 05:08 AM
msvx95's Avatar
It's just a phase
Is it a reverse thread like the PCV valve?
Old 03-23-2011, 06:00 AM
michael's Avatar
What Potholes ???
Normal threads.
Old 03-23-2011, 08:05 AM
The PCV has normal threads too....it's just upside down. when working on it, so it feels like you are tightening it, even though you are loosing in it
Old 03-23-2011, 08:45 AM
Huskymaniac's Avatar
Uses the ignore feature
Good.
causing you to go
Agreed! I learned the hard way with the temp gauge sensor. The aftermarket sensors can be crap.
Tony
Old 03-23-2011, 06:06 PM
msvx95's Avatar
It's just a phase
All very good info...I picked up my sensor today at the dealership. Apparently they are used in newer subbies too.
