Old 03-07-2011, 08:28 PM
clarkerussell clarkerussell is offline
Any pictures/diagrams for a homemade crankshaft pulley tool?
Hello all,
I'm about to start putting the pulleys and timing belt back on tomorrow, and I was looking for any advice/pictures/etc on making the crankshaft tool. I'm guessing that I need to manufacture something out of flat stock and some bolts, but I'm looking for some guidance. Thanks in advance.
Clarke
Old 03-07-2011, 08:50 PM
Cam Cam is offline
Re: Any pictures/diagrams for a homemade crankshaft pulley tool?
Find my engine build thread. There is a pic of mine in there on the last couple pages
EDIT : Found it for ya
http://www.subaru-svx.net/forum/show...&postcount=136
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 03-07-2011, 09:03 PM
Cam Cam is offline
It's a 3/4 inch hole (i think) with 4 holes around it. 3" between each stud, going across.
...........1
.........2..3
...........4
So, if that where the stud layout, there is 3 inches between 1 and 4, and 2 and 3. They cross at exactly half way, which is where the 5th hole (for the extension) fits. Just big enough for the extension to fit, so the socket must be preloaded onto the crank bolt, then install tool, then attach torque wrench, and BAM!
I used 3" grade 8, 5/16th diameter bolts.
Cam
'92 Ls-L Dark Teal
Old 03-07-2011, 09:25 PM
Thanks Cam, you have been VERY helpful these past two weeks!
So is this the procedure:
1) slide pulley on shaft
2) thread bolt on finger tight
3) install socket
4) attach extension
5) attach tool into pulley holes
6) attach torque wrench to extension
7) hold pulley tool still
8) torque bolt to spec (something like 90 ft/lb, I think)
Sound right?
Old 03-07-2011, 09:42 PM
3) install socket
4) attach extension
8) torque bolt to spec 108-123 ft/lb
http://www.subaru-svx.net/photos/fil...iles/44342.doc
Old 03-07-2011, 09:44 PM
Cam Cam is offline
2) thread bolt on finger tight (with thread lock)
3) install socket
4) attach tool into pulley
5) attach torque wrench to extension
6) insert extension through tool into socket
8) torque bolt to spec (something like 90 ft/lb, I think) (I think I did 115 ft./lb.)
Sound right?
With my adjustments (I must admit, minor adjustments), that sounds perfect
No worries, I am here to help when I can and learn when the need arises. People here have been very kind, so I try to repay the favor.
EDIT: Files, you always gotta beat me to it, huh?
Cam
'92 Ls-L Dark Teal
Old 03-08-2011, 07:45 AM
Is it possible to purchase the official tool from Subaru?
If so, it might be worth exploring a rental service for it. I've done it with the Airbag reset tool for BMW's. It's a tool that is rarely used, but costs about $200. I "rent" it for $220 and when it is returned I return the $200 deposit. It ends up costing the end user $20 + return shipping costs. Since I pay for shipping + Insurance of the device, I don't really end up making much money, but that's not really the point.
So, Cam... Are you interested in "renting" your tool so we don't have to fab something up every time?
Old 03-08-2011, 02:19 PM
Cam Cam is offline
I'd rather the tool doesn't leave my house, to be honest.
I tried my local subaru dealer about a year ago on some tools, and they told me that they don't usually supply them to customers. I said that I would be willing to deal with their tool vendor directly, but they declined to give me the information. They called me back saying a wrist pin puller and circlip pliers would cost a few hundred a piece or some crazy amount. So I went to harbor freight and spent 30 bucks on tools to modify and make work. Mission accomplished.
The point I am trying to make is that there is often a tool or materials readily available if you have a little ingenuity to spare.
As far as renting a tool, I am not sure if there is a place that would do it. I tried MAC tools, MATCO, and Snap-on. No one had something that would work without guess and check.
It would be easiest to just make one. Then you have it forever.
EDIT: someone found a crank pulley tool for a ?legacy? a while back on ebay. Haven't ran across an SVX one yet.
Cam
'92 Ls-L Dark Teal
Old 03-09-2011, 09:48 AM
alia176 alia176 is offline
I may be late to this thread but the way I removed crankshaft pulleys is to stop the flexplate from turning. You can see the teeth of the flexplate through the inspection hole near the top of the bellhousing. Usually, I have a helper stick a large flat head screwdriver into one of the tooth and have it rest against the side of the inspection hole while I turn the crankshaft bolt. Pretty simple I think.
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 03-09-2011, 11:39 AM
kwren's Avatar
kwren kwren is offline
I just woke up a bit ago, but are we talking about removing a crankshaft pulley, a camshaft pulley or a crankshaft pulley bolt
Keith
Old 03-09-2011, 12:24 PM
Whats a "helper"?
Old 03-09-2011, 07:54 PM
Keith
I was referring to INSTALLING the crankshaft pulley bolt. I removed it using Immortal_Suby's starter trick. Now I'm trying to get it installed again.
Clarke
Old 03-09-2011, 11:53 PM
kwren's Avatar
Clarke
I use the same big old break-over bar, the socket, and a big old mauler! Always works like a champ!
A big boxend wrench and a mauler work pretty good as well but you need a big HD wrench
Keith
Old 03-10-2011, 07:15 PM
immortal_suby's Avatar
Thread Killah
Clarke
I can't claim that trick - I learned it on here too. Not sure who was the originator, but it sounds like something Huck would do.
Locker Link
2015 BRZ Limited 6MT
Old 03-11-2011, 01:34 AM
kwren's Avatar
Seems to me it was Huck!
Keith
