Old 07-17-2008, 03:15 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
Exclamation Didn't realize that the transmission problem jokes were that serious.
Well, I've put less than 100 miles on the car, and today the trans started slipping in the 1st to 2nd shift. I wanna cry. When I owned an Impreza, we had a tranny cocktail of redline transmission fluid and GM syncromesh that'd keep us going. Is there anything similar here? I'm willing to pay now to avoid not having a moving car. Recommendations?
Old 07-17-2008, 05:06 PM
Re: Didn't realize that the transmission problem jokes were that serious.
Check the trans fluid... make sure the fluid quality and level are good. Start there.
Old 07-17-2008, 06:02 PM
Cynic's Avatar
Cynic Cynic is offline
I DID cry...
+1 on Tom's advice.
Cyn
92 Ebony Pearl LS-L 199,000K New Tranny (my DD)
89 Chevy Sprint (for when my baby's in the shop)
05 Mazda 3 (Hubby's DD)
"You win some, you lose some, you wreak some." Dale Earnhardt
Old 07-17-2008, 06:38 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
It's obvious that the previous owner did a job on you and knew it had issues. When it first starts it won't do it at normal temperatures and driving, but will slip when the tranny fluid reaches higher temps.
If I live in Jersey (God forbid) and had the money I would have it redone by LevelTen transmission. Of course its pricey, but apparently well worth it.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 07-17-2008, 10:39 PM
Lee
If I lived in New Jersey (and was not a mechanic,) I would take it to
All Wheel Drive and Young Tom!
Thousands less, and more experience!
Old Tom.
Old 07-18-2008, 08:33 PM
seion seion is offline
Subaru Engineer Wanabe
Relax, here are some good steps to follow:
1) Perform a band adjustment on the tranny. Do a search or look at the How Tos and you should be able to find it. If this fixes or reduces the symptoms of slipping, then proceed with:
2) Draining the tranny pan, get the tranny oil pan off, replace the internal filter with WIX 58969.
3) Replace the exernal filter with a Permacool external tranny oil filter.
4) Add an external tranny oil cooler.
5) Replace the pan with the new gasket, fill the tranny via the tranny dip stick tube with ~10 qts Valvoline DEXRON III.
6) Add 1 or 2 qts of LUCAS TRANSMISSION STOP SLIP for preventive maintenance (it has wonders for me).
If you need help, we'll be here.
Cars I've worked on:
'05 Subaru Impreza STi, '02 Subaru Impreza WRX Wagon, '01 Toyota Celica GT, '98 Subaru Legacy GT 2.5 Sedan, '96 Isuzu Rodeo, '95 Jeep Cherokee 2WD, '94 Plymouth Sundance, '94 Subaru SVX LSi, '93 Subaru Impreza, '92 Subaru SVX LS-L, 2003 Subaru Baja.
