Old 06-01-2008, 10:25 PM
prtsguy prtsguy is offline
I can't belive I broke a timing belt!!!!
How much trouble am I in? When I tore it down I found ALL of the idler pulleys had seized and/or lost all of the ball bearings. I'm a former auto machinist and can do the valves if I need to but I'm not really looking forward to going that deep into the engine.sooo....... my question is are they notorious for bending valves?
as a footnote, I do perform my maintanance and such but the car had set for three years before I bought it and had low miles on a dealer installed engine. Don't think bad of me, please. It's just slipped by me.
It's a '94 awd with the 3.0
Old 06-01-2008, 10:31 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
The EG33 is non-interference. You're fine.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-01-2008, 10:33 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
No Problem
There is not problem with engine damage on timing belt breakage on this engine. There is no problems with valve clearance. So, all you should really need is one of the timing belt kits they sell on Ebay that includes the timing belt and the idler pulleys. It might be a good idea to replace the water pump also, if the car has a significant number of miles on it as it is easily accessible when replacing the timing belt.
My daughter with no mechanic experience did her timing belt with a set of manuals and some telephone instructions, so it should not be a problem for a mechanic.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 06-01-2008, 10:52 PM
zukiru's Avatar
zukiru zukiru is offline
Winona is my yang.
^^that sounds like a challenge to me!
Old 06-02-2008, 11:11 AM
Check the water pump too.....
Old 06-02-2008, 02:02 PM
crazyhorse's Avatar
242,000 mi on oem trans
For the $50-75 that a waterpump costs, and the PITA it is to get to, it makes sense to me to slap one on while you're in there.
"42"
Current Stable By Age:
Old 06-02-2008, 02:14 PM
Definitely do the water pump while you are in there for preventative maintenance.
Old 06-04-2008, 07:27 PM
That's rought, timing belts are pretty strong. I used one to lift a complete EJ25 with 4EAT attached today...
Old 06-04-2008, 08:55 PM
It's Just Eric's Avatar
Missing in action
Hmm...all the idlers seized up..Thatll ruin a belt easy.
luckily, the eg33 is a non interference engine. Your valves are fine. Just order up the idlers, belt, and water pump.There is a kit available on ebay with all of theese components that we have used with great sucess .you may want to look into getting a front main seal and lower cam seals as well, since everything wil be apart anyway, replacing these isnt a bad idea, as they often leak at this age.
R.I.P Cool Signature.
