Old 11-20-2007, 06:43 PM
94SubieSVX's Avatar
OOC for a while
Doing a Mild Restore soon, a few questions.
I've been planning on doing a mild restore/rebuild of my svx sometime next year. It won't be anything way too in-depth I think, but I have a few questions on how I should go about doing it. What I plan on doing is pulling the motor and doing a complete reseal, using the gasket kit from Subaru(the $300 one). I don't plan on building the entire engine completely, just all of the normal wear parts. I want to do the Water and Oil pumps, Timing belt, I was also thinking of replacing all of the external hoses but saw in another thread that it would cost about $1k. What else should I do to the motor while I have it apart? I don't plan on going with the forged pistons/rods/pins etc as I don't see my self going s/c anytime soon.
Also, when I have the motor out and apart I want to convert to AWD and 5speed at the same time.
For the AWD I know that I need the:
  1. AWD rear subframe
  2. Rear diff(same gears as the tranny)
  3. Rear axles - Can I just use stock SVX axles with the Legacy 5speed?
  4. Rear driveshaft - Do I need a stock SVX d/s or would I need to get a WRX(I think??) driveshaft and get it extended 2"?
  5. Do I need to get rear hubs from an AWD svx to accept the rear axles? Or can I use the stock hubs on mine now?
  6. Everything needed to convert - YToms $1k kit, etc.
I also am going to replace the majority of the suspension bushings. I already bought the front and rear swaybar bushings, as well as the $20/20min mod from OT. Is there any other important bushings that I should replace while I have those areas apart?
Lastly(I hope), I plan on getting the GC coilovers to use in conjunction with my Konis. I think my Konis are leaking now, as they sag so much that the rear wheels are almost 1" tucked in the fenderwell. I want to send them back to get new/rebuilt ones under warranty. If they're leaking the should get replaced for free right? I'm not too educated on this so any input would be great.
Anyway back to the GC springs, what would be a good spring rate for me? Being it's a daily driver and occasional Autox-er, I don't want it to be too rough, but I want it stiff enough that it can handle pretty well in racing.
I think I may have to replace the strut top mounts because I've heard Konis w/ stock springs tend to ruin them. What should I look for when I take them apart?
Ok, now this is it, I promise.
And also I'm going to upgrade to the Race Concepts brake kit that OT distributes. How hard is it to switch out to the stainless lines? I'm sure compared to what I listed above, this should be a piece of cake.
Lastly, I'm just gonna clean everything up around the engine bay/underbody. Clean up all of the spot rust, give some of the suspenion pieces a coat of rust preventing paint, etc.
All-in-all, any general feedback on what I should get or how I should go about doing this would be great. It won't be happening for a while since I don't have many funds right now to afford it, plus winter is practically here, with it snowing less than 2hrs from me.
Thanks guys/gals
bLAh
Old 11-20-2007, 07:44 PM
Only tid-bit I can give is that I replaced almost all the hoses under the hood with withe factory ones or crush resistant silicon ones for around 150. this even included the stupid windshield squirter lines.
blk 92' LSL w/ average mods
Old 11-20-2007, 07:46 PM
With a 5MT you'll need an extended driveshaft, or a Legacy one. YT sells extended SVX driveshafts with his kit I believe.
Old 11-20-2007, 07:50 PM
I can help with all your needs and desires.... for your car you sicko But yeah, when you come to pick up that subframe at the meet we will chat about your requirements and your options
Old 11-20-2007, 09:32 PM
94SubieSVX's Avatar
OOC for a while
Could you tell me which you did with factory hoses and which with the crush resistant silicone? Idk how crush resistant silicon holds up, so how have yours been doing?
You mean an extended as in stock SVX with the 2" entension? Will the Legacy one bolt right up? Or I can go the easy route and get it with YT's kit
Bow chicka wow wowww Awsome, yeah I might be stayin over that Saturday too so we can talk about it over a nice cup of Tea
bLAh
Old 11-20-2007, 09:53 PM
It's Just Eric's Avatar
Missing in action
Woohoo! garage weekend minimeet
R.I.P Cool Signature.
Old 11-20-2007, 09:55 PM
94SubieSVX's Avatar
OOC for a while
Whos bringin the Asti???
bLAh
Old 11-21-2007, 02:08 PM
redlightningsvx's Avatar
Collision Refinishing Tech
change the knock sensors and pcv valve plus while you change the gaskets you could throw on some thermoblock spacers
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 11-21-2007, 03:04 PM
94SubieSVX's Avatar
OOC for a while
Are thermoblock spacers the same as Phenolic?
bLAh
Old 11-21-2007, 07:47 PM
Yes ..............
Seth
Past subies:
Other toys:
Old 11-21-2007, 07:50 PM
94SubieSVX's Avatar
OOC for a while
Yes ..............
Good thing you reminded me, thanks. I meant to put that in the original post, but I got caught up in everything else I was listing
Another thing, is I'm going to replace the IRIS check valve, as per OT's suggestion. The hose it's connected to is pretty stiff and if I play with it at all it feels like it's gonna break.
bLAh
Old 11-21-2007, 08:53 PM
Sounds like allot of work to be done! I'll get back to you regarding the hoses.
Old 11-21-2007, 09:29 PM
94SubieSVX's Avatar
OOC for a while
Yeah I guess you can say that ...It's ok though, because I won't be on any time restraints so I can take my time with everything and learn some things at the same time.
bLAh
Old 11-22-2007, 01:45 AM
Roo Roo is offline
Send a message via AIM to Roo Send a message via Yahoo to Roo
I can. I live just about 45 minutes away...from Asti, that is.
'92 SVX LS-L
Project Car for Open Road Racing
Old 11-22-2007, 06:14 AM
SVX_MY_BABY's Avatar
Check the tie rods and trailing arms. Oh and the bearings. You'll have it all apart so over half the work is done for these items. You'll also have the exhaust off so you may want to check the brake and fuel lines if you are in a rust prone area. They tend to rust out where they go over the gas tank, which would have to be dropped in order to see.(which requires the removal of the exhaust)
