Re: RADIATOR... cRaCk!.. HELP!?
I ordered thru Radsus on ebay.. but got a Silla from about 5 miles from my house.. here in Fresno! Ha! I haven't put it in yet.. I'll let you know about fitment.. . SURE LOOKS NEW!!!
It will fit perfectly and last for years. Just don't order an AC condenser, they're on back order and wont't be available any time soon.
I ordered from radsus. Had a leak on my first one which they exchanged for me. 2nd radiator is going on it's 4th or 5th year. Would definitely buy from them again.
Appeared to be exactly the same.. except drain plug had no included tube nipple. Are they remanufactured?
Seems to work too! Thanks, Jim
YIKES! .. I'm driving along with my new radiator.. working to go to work for 2 (?) weeks .. ALL OF A SUDDEN .. Overheating.. YIKES! (typical 100 degrees F here in summer)
No radiator leaks Coolant Overflow Tank full No cap coolant spray evident If AC on.. generally worse (or AC temp goes up from 40's and 50's to 80's!) Gauge going up to red.. then back down near normal.. no obvious reason But, later when cooler outside (85 degrees F).. still goes up a little with AC off! Seems the only intermittent explanation.. could be THERMOSTAT??? HELP!!! Any Ideas Appreciated Jim
New radiator.. worked fine 2 weeks..
New OEM thermostat at assembly of "rebuilt" engine.. (June) New water pump..at assembly of low mileage engine (Nate/Pennsylvania-about Feb) Put new Thermostat in this am with proper rubber gasket seal (thot that was it! Leaking a little under housing (wrong rubber originally!).. Still overheating on way to work! Gauge @ 1:30 to 2 o'clock .. ??? Could it be the AC causing this?? HELP!!! Jim
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 09-16-2013 at 01:57 PM. |
I quit using oem tstat's as iv'e have too many over 10 go bad in months. I use the failsafe ones at autozone with oem gasket now with no problems. Also make sure the system is bled properly.
Also are both fans kicking on?
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
About 500 to 1000 miles .. at most!
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 09-16-2013 at 02:14 PM. |
I used an OEM gasket with my old (sitting around, but new) OEM thermostat when putting this engine together about June. Bought an OEM rubber gasket too.. It dint have center groove for thermostat sheet metal (???) .. So I think it caused leak below housing .. not sealed properly.. I just put rubber gasket on top of thermostat, then bolted.. dripping off a little last nite when I was checking around thermostat and looking for other leaks. Got Napa gasket which fits proper.. used Pep Boys Stant small (not OEM size-they make two) thermostat this morning with the proper gasket.. fit good now, but .. STILL STARTED TO OVERHEAT ON MY WAY TO WORK 30 miles away! What about the air pocket I've been told about?? Is that the bleeding you're talking about? HELP! Thanks, Jim
Raise the car about a foot or so in the front, with the motor cooled remove the rad cap and gentle squeeze the upper hose till all bubbles are pretty much gone, then make sure the rad is topped off. After that turn the car on with the heat on MAX with the rad cap off still and let it get to temp which will open the t stat and drop the coolantin the rad slightly. When you see no bubles put the cap on and shut the car off and you should be good.
Thanks. I did that when filling.. everything, but did not run engine?? I'll try it..
Jim
#28
What I do is pretty much what redlightning suggested, except I use one of these: http://www.amazon.com/dp/B001A4EAV0/
Put that on where the radiator cap goes, then fill it up and keep some coolant in the funnel. Air will bubble out of it, and coolant will replace the air until there's no air left. The funnel's not necessary but it saves the trouble of having to constantly top off the radiator with coolant. Running the engine definitely helps tremendously with working the air out, by keeping the bubbles circulating until they get out through the funnel/rad fill opening.
#29
Jim
