Old 01-02-2008, 04:08 PM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
WTB: huge list of stuff
My car is turning into a money pit. I priced all the stuff I need from the local Subaru parts place, and the whole list comes in at just under $2700.
Obviously I would like to save a little cash here and there if I could.
The list:
Fuel Tank*
Sending unit
Rear diff bearings (all 4)*
Timing Belt
Timing Belt Tensioner
Timing Belt Covers (all 3 pieces)
Water Pump
Thermostat & seal
Lower Rad Hose*
Cam & Crank seals
Some of this stuff I am just replacing because I will be "in there" anyway, and I don't know if it is bad or not. The major issues are marked with an asterisk.
Thanks.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 01-02-2008, 04:26 PM
There's usually a timing belt kit on Ebay from Prefered Components at a decent price, sometimes there's a water pump packaged with it.
Old 01-02-2008, 04:27 PM
sicksubie's Avatar
PM'd you....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 01-02-2008, 04:52 PM
SomethingElse's Avatar
word words wording
you would be suprised how much of that stuff advanced auto carries. Also when you say rear diff bearing, do you mean rear wheel bearing?
Eric
Old 01-02-2008, 04:56 PM
No, I mean pinion and carrier bearings inside the rear differential.
Old 01-02-2008, 06:17 PM
Speedklix's Avatar
Speedklix Speedklix is offline
Locker Link Solution
wow, dead already? or is it for the stock car? if it is for the stocker, save yourself the trouble and just buy a newer low miles diff.
-Mike
ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC]
In progess: track down mystery noise <-identified, paint the new dash, get better pic
Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165
Member #995 | My Locker | My New Locker
Catch you next at: ? Auto-X ?
Old 01-02-2008, 08:28 PM
This is for the modified car. It uses the stock diff housing and parts with a 3.90 ring gear from an older Legacy turbo, so presumably the bearings are original, with 107,000+ miles on them.
Old 01-02-2008, 09:42 PM
I would only replace the lower radiator hose with a new one. It isn't worth the amount you save to get a used one.
Old 01-02-2008, 10:03 PM
The list:
Fuel Tank* (got it)
Sending unit (got it)
Rear diff bearings (all 4)* (don't be silly, get an R180 with matching axles)
Timing Belt (get the Ebay kit with the idlers and water pump w/ gasket)
Timing Belt Tensioner (got it)
Timing Belt Covers (all 3 pieces) (got em)
Water Pump
Thermostat & seal (buy them new)
Lower Rad Hose* (buy new)
Cam & Crank seals (buy new)
Thanks.
I marked everything we have here for you if you want. also added commentary on what you should buy new. The rear, get the R180 and sti axles with it as it is far superior than the 160 anyway... I would also go back to the shop that did the work and ream them out for screwing up the rear diff. Prob not bearings.... its probobly because they didn't pattern the gears properly.
Old 01-03-2008, 03:48 PM
PMed you, Tom.
