Damn wheel bearings!!!!
Since I bought the car with about 74K miles on it in late 2010 I have replaced the left rear bearing twice and the right once. The right sounds like it is starting to go again. When I did the left for the second time, Nate had suggested replacing the hub too so I did that. I also replaced the grease with Redline grease but I am not sure that was necessary as Timken claims they pack them now with the proper grease. I also don't know if I did a particularly good job. So I guess I will replace the hub with the right bearing this second time around on the right side. Maybe sitting for a year contributed to this or maybe it is because I didn't replace the hub the first time but it is damned frustrating. Hopefully I am done with this crap.
Anyone know how I can get a bearing and hub quickly? Do most dealers carry them or am I going to be forced to wait until they come from a warehouse somewhere?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 11-02-2014 at 08:27 AM. |
Re: Damn wheel bearings!!!!
Did you torque the nut and press the bearing properly? Do you have aftermarket axles? There has to be a reason for the failures. Maybe you have the wrong offset on your wheels.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
There's gotta be a way to get STi hubs to work. We use the same bearings and lateral links and struts for the most part...
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Now, that being said, a trailing arm isn't a huge challenge for someone with half-decent fab skills. The non-parallel pivot points would put stress on the bushings unless a heim joint was used for the forward end to free up some motion.
The strut mounting point on a rear STi knuckle is in a different place than on the SVX also. On the SVX it is vertically above the wheelbearing, on the STi it is off to the side. This puts the STi knuckle at a really bad angle if you tried to mount it up.
However I think he is asking of the STi wheel hub and wheel bearing work on the SVX. This is something I've been curious about also seeing as we use the same 190mm parking brake assembly and can direct bolt the STi rear CV shafts in. It would be interesting to cross reference the rear hub and bearing part numbers between the two. |
what about Tribeca?
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
