Old 01-06-2012, 07:54 AM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
coilovers questions
Looking at GC coilovers w/Koni inserts and someone recommended I look at the custom made ones on e bay. I sent a message to the seller (Australia ebay, guy in France? he said theirs are better/last longer. I know nothing about coilovers and struts. He suggested I go with the mono tube dampers and 1 way adjustment, camber plates front/rear. It's direct bolt in, no fabbing. He also said 2 ways adjustable damping and dual springs are nice but more expensive.
It's all Greek to me. Anyone have any time to educate me? Suggestion?
Old 01-06-2012, 08:19 AM
Re: coilovers questions
Coilovers have adjustable damping levels in the shocks, meaning you can tune how soft or stiff they are.
Single adjustable means that both compression and rebound are controlled by the same knob. Dual adjustable means that compression and rebound are separately adjustable (more of a racing feature).
Camber plates will make the upper mount for the struts adjustable and allow you to control the camber angle. Not a whole lot of point of having them in the rear, you have to strip out the entire rear interior to be able to adjust them every time you do an alignment. I have them on my car and can't see myself ever touching them after I installed them, just way too much work.
Now, everything being said, uber cheap coilovers always make me a bit nervous. One of the most likely reasons is that the shock isn't valved or tuned to specific vehicles, just a generic unit that they put into every system they sell. This means that you're getting the same equipment in a 2900 pound Nissan 240 as you would in your 3500 lb SVX. Obviously that is going to make a difference in the way things work. Just my opinion though, your mileage may vary.
Old 01-06-2012, 08:22 AM
I have ordered a set of the "ebay" coilovers and am awaiting their arrival to test them out. I have talked with the ebay seller extensively and they seem to be a very good product. Once I get them in my hands, we will be able to check the quality as well as the performance of the units.
Old 01-06-2012, 08:25 AM
92 SVX 92 SVX is offline
Looking at the ad (keeping in mind they dont always tell the complete story, or even truth in some cases)
I think these are all done on extensive specs for each car.
http://www.ebay.com.au/itm/COILOVERS...item19cc1a9f1f
Old 01-06-2012, 08:27 AM
What coil stiffness and rates would you suggest for a hard street driven car?
By that I mean normal city and highways but fast turns and fast starts and stops?
With the possibility of auto x but that would be a rare event.
Oh and low almost as low as the removed.
oops I ment this pic
http://www.subaru-svx.net/forum/showthread.php?t=58977
Old 01-06-2012, 09:15 AM
The ebay coilovers don't allow for the stock strut mounts...correct? Without the stock rubber strut mounts, won't this make the ride significantly more harsh?
Looks like the mounting bracket on the ebay coilovers is simply a steel plate...
Old 01-06-2012, 09:23 AM
I may be completely wrong on this(if I am I apologize) but it would seem the strut goes through the top mount same as a stock one so i imagine you could use the stock one.
However I dont believe the ride quality would diminish much, if at all as the strut is still going to dampen the bounce.
Old 01-06-2012, 09:24 AM
The OEM mounts still mount metal plate to the metal body with rubber inside the mount.
- Steel top plates with rubber bushes for comfort, without compromising road feel
As I've said in this thread as well as the other one. We have ordered a set to test out. We will report the quality and anything else that would be of importance to anyone debating. With these, stock ride height and spring rates are still available to those that would want a stock feel but a more reliable upgrade as there have been issues with OEM replacement struts in years past. Also, OEM mounts at any point in time, Subaru could choose to discontinue making them leaving no option and therefore quite a few SVXes destined to be parted out as a strut mount is pretty vital to operation of a car.
These also offer many optioins that are completely unavailable other than the Aragosta that cost as much as I can buy about 10 SVXes for. This is all at a great price, and from talks back and forth, should be of great quality and guaranteed fitment and reliability.
