Old 05-27-2008, 10:20 AM
LarryIII LarryIII is offline
Aviation requirements are very, very different than those for automotive applications, as has been stated in previous posts.
So the "aircraft EG-33" that is twin turbocharged may perform very poorly when put into an SVX.
I think young Tom is correct. I vaugely remember seeing the photo of this engine many years ago, either on this site or the Yahoo site.
Old 05-27-2008, 04:36 PM
oab_au oab_au is offline
A supercharger can not compensate for air density, the same as a turbo charger can, in aircraft use.
Developing a EG33 for aircraft use, has the engine speed limited to around 4000 rpm, due to the maximum prop tip speed.
One Arm Bloke.
Tell it like it is!
Old 05-27-2008, 05:17 PM
This all depends on what kind of supercharger you are using... The guys in aviation opted out of a TT setup for a centrifugal s/c.
Old 05-27-2008, 05:56 PM
With a turbo in aircraft, as the air gets thinner with altitude, the pressure difference across the turbine increases, so the turbine/compressor increases its speed to maintain the boost pressure. The other forms can't compensate for the air density the same.
One Arm Bloke.
Tell it like it is!
Old 05-27-2008, 06:08 PM
Turbo's in aircraft are mainly used to maintain power as the plane climbs. They can be used to increase power, but this is very rare. Superchargers are used as the big power-boosters, often for planes that do not reach altitudes where thin air is an issue.
My favorite example is the Argus maritime patrol plane. It had 4 engines, each was a twin bank radial, 9 cylinders per bank. Each engine was triple-turbo'd and supercharger. Full power was only used on take-off with a heavy load, and methanol injection was used to keep the engines from melting into big hunks of iron.
Old 05-27-2008, 08:53 PM
Great, i guess I read it wrong as to why they lost the TT idea and went to a centrifugal.
Old 05-27-2008, 09:01 PM
RSVX RSVX is offline
Network Design Administrator
Perhaps if either of you were to provide proof other than your word, that would help each other in understanding.
After all, you could BOTH be right.
Life is a game. Play to win.
Old 05-27-2008, 09:33 PM
Man I had to dig back to '03 for this... I knew it was there though
http://www.sdsefi.com/air31.htm
Old 05-27-2008, 09:42 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
I don't care how powerful this engine is, I see one minor problem that will keep this thing on the ground...
Old 05-28-2008, 07:38 AM
The lack of smooth paint adding too much drag?
Old 05-28-2008, 10:27 AM
jeffast jeffast is offline
I kill more trannies then god
it didn't actually say why he went for the super charger over the turbos...
1991 xt6 eg33?
1993 gc track car
Old 05-28-2008, 10:39 AM
yes but there was a hefty discussion about it years ago... Like I said, there can only be one reason to scrap such a heavily invested project, that is if it was not working the way it needed to and there was no foreseeable positive outcome from it. I am not going to argue this I was merely stated what I had read in the past.
Old 05-28-2008, 04:25 PM
crazyhorse's Avatar
242,000 mi on oem trans
I have no intenton of stirring the pot, but in that link it sates that the engine popped a seal out of the prop drive on the dyno. Could it possibly be that the EG33TT made TOO much hp for the reduction drive? Thus prompting the switch to the EG33SC.
Either way, with 350+ hp at the crank, in that tiny airframe, that thing ought to fly, wings optional!
"42"
Current Stable By Age:
Old 05-28-2008, 04:27 PM
I doubt it... The seal would only pop out if the fluids inside the housing got so hot they expanded and pushed it out... Or some other mech issue. they never explained it.
Old 05-28-2008, 10:11 PM
It's Just Eric's Avatar
Missing in action
...So to answer your question...no, Turbocharging svxi isnt very common, though there have been some one off fabrications done by varoius people for whatever reason (Many dont end up in an svx) Perfect example...the one of the fastest awd drag cars is made by tony rigoli proformance, and powered by a turbo eg33
The biggest issue is there arent any plug and play stand alone or piggy back ecu's being made publicly available, making the job beyond your average do it yourselfer.
R.I.P Cool Signature.
